Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: In-ground pool virgin needs some advice.
    May 2015
    Lexington, KY
    73
    Hello fellow pool owners. I bought a home last fall with an inground saltwater pool. It has an Aqua Rite system. I had a pool company come out and open it for me on Thursday. They dumped 3 bottles of a white powdery substance and a bottle of blue liquid (after they opened the pool). They recommended that I go back to their store to test my water today so I did. Here are the results that are not ideal:
    CYA: 29
    Tot. Chlorine: 7.4
    FC: 7
    pH: 7.1
    Adj. Total Alk: 63
    Tot. Hardness: 143
    Borates 13
    They recommended that today, I:
    1. Pour 1 bottle strip kwik through skimmer with basket out while backwashing. Then backwash and rinse and repeat with Kleen It.
    2. 1.5 bottles saltscapes shock
    1 bucket optimizer
    9.5 lbs lo n slo
    5.5 bottles stain & seale
    1 bottle stabilizer
    Day 2:
    1 bucket optimizer
    9.5 lbs lo n slo
    20 lbs BP 100
    Weekly:
    1.5 renewals into water
    Is this what I'm supposed to be doing? I'm quite shocked that I'm putting in this much chemicals into a saltwater pool, but I'm also brand new with this.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: In-ground pool virgin needs some advice.
    Welcome to TFP
    Well, if you read around here you will find that pool store testing is always suspect. Our maintenance of pools is based on accurate testing and only adding to the pool what it needs when it needs it.
    I would,suggest doing a little reading here and making sure you are comfortable with the techniques we use because they are really not comparable with what most pool stores advocate. Almost everything they are recommending you add to the pool we would not recommend.
    We are here to help!
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I would suggest doing NONE of that at this point, it is hard to say much about the state of your pool though without knowing what they added, and without having what we consider reliable test results. This is not to say that the test results you have been given are wrong, but that it is our experience on average pool store testing is wrong more often than it is right. Remember they make money by selling you more chemicals, and test results that say you need to add this or that makes them money, and even if those tests are wrong, they get to make yet more money fixing what last weeks test had wrong.
    Instead I would say to start with ordering one of the suggested pool test kits from the pool school link above (see my sig. for the TF-100 link), this is step on to get it on order as it take a few days to get to you. The next step is to understand a bit more about what is going on in your pool, don't worry we are here to help along the way, to do this you should read the ABC's section of pool school http://www.troublefreepool.com/conte...ater-chemistry, once you get through there we will have some basic terminology in common and can help more. We also need you to update your signature with your pool information, this lets us tell at a glance the details about your pool, as the suggestions for a vinyl liner pool will be different from a plaster pool, etc. You also mention that you have a SWG (salt water chlorine generator), yet there is no salt level reported in your test results, was this an oversight?
    Ike
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Oh good gosh!
    Man please DONT add all that stuff. Its crazy!
    If you dont remember anything else, remember this. The pool store job is to sell you as much snake oil as they can. Thats why they exist.
    Your Job is to learn what your pool actually needs, and with that, you have found the right place.
    The first thing you need to do is get yourself a reliable test kit and be able to test the water yourself. The pool store testing is flawed, to the nth degree. We recommend either of the two following kits.
    The TF100, (best back for the buck) and the taylor K2006. The TF100 only avialable online at www.tftestkits.net
    The Taylor availble at various online sites.
    Once you get a test kit, and test the water, then post up some test results and we can help you.
    In the meantime, we recommend reading up on the ABCs of pool chemistry (click the pool school button).
    And here are some handy references.
    http://www.troublefreepool.com/conte...mmended-levels
    http://www.troublefreepool.com/conte...art-slam-shock
    and here is a tool that you will need to use for as long as you own your pool. Just enter how many gallons you have, at the top left where it says volume.
    in the boxes on the left most column, enter the test value
    in the next box, to the right, enter your target (see recommended levels)
    then click calculate buttom and Pool Math will tell you how much of something to add. Its just that easy.
    http://www.troublefreepool.com/calc.html
    hope this helps get you started.
    Please ask all the questions you have and we will help you...that's why we are here.
    Divin Dave,
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    When you order the TF100, you should also order the Salt Test Strips (Aqua Chek) if you don't have them already.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    May 2015
    Lexington, KY
    73
    Thanks for the info. Before I posted this thread, I read a lot of the basics about how to operate, the terminology, etc from this website. This website is incredibly helpful for newbies (and probably veteran pool owners) so I'm very grateful for the sharing of knowledge.
    The pool opening cost me $400 on Thursday (they dumped 5 bottles of chemicals into the pool) and another $650 today (but I have not used them yet). I will definitely order those test strips and go that route. My apprehension is that I'm such a newbie that I do not want to destroy an expensive pool and the associated equipment (filter, pump, heater) over $600. Both are a lot of money, but I'd rather be on the lower end of "a lot of money" than the higher end of it. Haha. As a newbie, I've always heard that SWG were easier to maintain and less chemicals so that was why I was so shocked at my wife bringing home $650 worth of chemicals (which, nothing against women, but my wife is very non-technical and I should've known better than to send her on our first trip, but I was extremely busy this morning).
    Quote Originally Posted by wkusae31 View Post
    Take whatever you can back and recoup that $650. As an aside, I'm pretty sure I've spent less than $650 in the last (almost) two years of non-SWG pool ownership. That is including testkit, new reagents, and chemicals (bleach and muriatic acid). I won't count natural gas or electricity. SWG pools are slightly easier to maintain as you don't need to add chlorine, or at least not as often as non-SWG pools.
    You really need to get a testkit though. As others have said, the TF-100 is the best bang for the buck, but the Taylor K2006 is essentially the same thing. Once you get those, post your numbers on here. There's a lot of very knowledgeable people here and will help you manage your pool.
    14,000 Gal IG Pool/500 Gal Attached Spa
    Pentair Whisperflow 1hp Single Speed Pump
    Sta-Rite Posi-Flo PTM-135 Cartridge Filter
    Hayward H400 Natural Gas Heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Welcome to TFP!
    Here is the recommended Water Balance for SWCGs.
    Here are the Recommended Pool Chemicals to maintain your pool.
    And use PoolMath to figure out how much to add.
    May 2015
    Lexington, KY
    73
    Hello everyone. Thanks for the tremendous help. Just wanted to follow-up with a few questions:
    1. I read on this website that the best time for the pump to run was during direct sunlight for a SWG. Do all pools have timers? I am fairly technical and cannot find a timer so I'm wondering what my pump set-up is, without one?
    2. As I stated before, I have an Aqua Rite system. It originally read 3000 (2 days ago when I had my percentage on 50%). Today it read 2900 so I increased my percentage to 70%. Is this OK or a dumb rookie mistake?
    3. The pool store, on my analysis sheet stated I have a 27,500 gallon pool. They closed and opened the pool for me in the fall/spring. I do not remember them measuring my pool. I measured and it is 40'long x 20' x 3' deep (half pool) and 8' deep (diving board half). According to the calculator on here, I have 34,400 gallons because I based it on 40'x20'x5.75'. Seems like 7,000 gallons is a big discrepancy so I did not want to overdo it with chemicals.
    Jul 2014
    Independence, KY
    220
    Is your pool a rectangle, oval, freeform, etc.? I have a 40x18 oval (3 foot radius in corner), 3 feet shallow and 8 feet deep. Just built, and CAD drawings show 23K gallons. Hard to believe that just 2 feet wider would give you that much more volume if yorus is an oval.
    IG W/Vinyl Liner Oval 18x40, 21K gal, Oval 3'-8'
    Pentair Intelliflo VS Pump, Sand Filter
    4knights's Avatar
    NE Kansas
    419
    Welcome to TFP-
    You're wife does not need to be technical to understand the basics of your pool. if she is at home more than you, she will be the best person to know( see ) the changes in your pool. It's amazing at how clear your pool can be if you follow the simple TFPC method. My salt water pool is truly self sustaining most of the swim season.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    May 2014
    Franklin, NC
    9,184
    Most pools have timers, but it is not a necessity. You can turn it on manually and the previous owner may have done that. Check this out to see what common ones look like http://www.troublefreepool.com/conte...pool-equipment.
    You increase or decrease the percentage to add more or less chlorine to the pool.
    As you begin to add chemicals pay attention to the effect they have on the pool. Mine is free form pool and I had no real idea, but through careful additions (when necessary) and watching the effect of the additions I narrowed down the pool size.
    Support the site
    May 2015
    Lexington, KY
    73
    Quote Originally Posted by Yev View Post
    Sorry, I should have stated that mine is a rectangle. The pool store estimates around 27,500 and from the math calculator on this website, it puts me around 34,000. Maybe the pool store is accurate if yours is 23,000 and fairly similar to mine?
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    My 16x36 is about 24k. It is a rectangle with 2ft radius I believe.
    Looks like you're a Topper alum right in the middle of the BBN. Welcome to the site.
    SCon36
    24,000 Gallon IG vinyl pool (16x36x8) with Hayward S200 sand filter and Hayward pump and heat pump. Built August 2011. I use a Taylor K-2005 test kit with a K-1515 add on.
    https://www.youtube.com/watch?v=bIgL...0MyAw&index=29
    May 2015
    Lexington, KY
    73
    Quote Originally Posted by SCon36 View Post
    Yes, I'm a diehard Topper fan.
    I just ordered the TF100 test kit with Stirrer, Taylor Salt Test, and Borates test. I'm very impatient so I'm hoping that it gets to me fairly quickly. I'm curious how these test results compare with the ones I received from the pool store. One thing that I'm surprised is that my CYA level is at 29 when it should be around 60-80 (per TFP website), but my FC level is at 7 (so I'm assuming it's safe to swim since it does not smell bleachy and not at the Shock Level).
    Pool Owner since Sept. 2014, but 2012(ish) in-ground pool. 40'x'20x3'(shallow)-8'(deep). Around 28,000 gallons. Vinyl liner. SWG. Aqua Rite with Hayward T-15 cell. Hayward Super Pump (self priming). Hayward Sand Filter. AquaPro Pro1100e Heat Pump. 2 main drains. 2 skimmers. 2 jets. 1 light. 1 diving board. Dolphin M4. TF-100 Test Kit.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    Should be fine. For your CYA, shock is 12 and target is 4. You should be fine swimming at 7.
    It is amazing to see all of the extras they're want you to buy.
    SCon36
    May 2015
    Lexington, KY
    73
    In preparation of getting my test kit, I'm rounding up the necessary chemicals so that I will be prepared to adjust my levels according to TFP. My wife bought SaltScapes Sunshield Stabilizer during her $650 expedition at the pool store. Is this the same as CYA (I read that it has a variety of names such as Stabilizer, Conditioner, etc) so I wanted to make sure that this is something that the TFP community is fine with to use? I did not know if there was a recommended brand or product that does a better job.
    SCon36's Avatar
    Jul 2014
    Bedford, KY
    121
    That is CYA. Should do the trick.
    SCon36
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    Am I reading their print out correctly where it says the Ideal CYA level is between 60-200????
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
  20. Back To Top    #20
    Nov 2010
    South Central Kentucky
    283
    Glad you found the board. Lots of good help here.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
