Thread: Upgrading pump
    May 2015
    DFW, TX
    2
    Upgrading pump
    Hi guys.. long time reader here and I love the site. First time posting.
    Motor died on my WhisperFlo WF-28 C and want to upgrade to Intelliflo VS (011018). I know I could just replace the motor, but I'd like to go ahead and have an all new wet end as well. My question is, is the gray nipple on my current pump inlet sch 80 pvc? Think I have enough room to cut the current one out and fit a new union without running into my jandy valve? Thanks.
    25k in ground, pentair cartridge filter, t-cell SWG, polaris 360, whisperflo wf-28c (dead!), intermatic mechanical timer
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Upgrading pump
    I,don't know if it's schedule 80, but it does appear you have sufficient room to add a union there. Carefully cute it off as close to,the pump as you can and you should have 3-4 inches to work with. Up you only need an inch nor so.
    Support the site
    May 2015
    DFW, TX
    2
    Re: Upgrading pump
    Got it in without any problems. As you said there was plenty of room for the union. Used Oatey All Purpose cement since I didn't know if it was pvc or cpvc. Purring away at 1500 rpm (300 W) right now and dry as a bone. Thanks!
