Thread: My first SLAM...encouragement needed...
    May 2015
    Avon, IN
    23
    Making sure I'm on the right track here with this... started my SLAM on Thursday, 5/7/15 at 9pm. My pool was clear but not sparkling. My initial testing numbers showed CC=3 so started the SLAM. Here's my process so far...
    5/7/15 9pm
    FC=11
    CC=3
    pH=less than 7.0
    TA=220
    CYA=40
    Added bleach (to goal of 16) and Borax (to goal of 7.2)
    10pm FC=17
    5/8/15 at 630am
    FC=14.5
    CC=1.0
    5/8/15 at 5pm
    FC=13.5
    CC=1
    pH=7.0
    TA=200
    CYA=50
    Added bleach (to higher goal of 20)
    Vacuumed
    5/8/15 at 630pm
    FC=21
    CC=0.5
    No additions
    5/8/15 at 830pm
    FC=21.5
    CC=1.0
    No additions
    5/8/15 at 940pm
    FC=22
    CC=1.0
    No additions
    5/9/15 at 7am
    FC=17
    CC=1.5
    Added bleach to goal of 20
    5/9/15 at 1130am
    FC=17.5
    CC=0.5
    CYA = 50-60? ***Rechecked my CYA again (because I had added some Wednesday to the skimmer before my test kit came since my strips were registering 0 - now I'm afraid it will go haywire!)
    Added bleach to goal of 24 since the sun is shining and it's daytime...
    Brushed pool
    I'm seeing blackish stuff in corners of pool and along edges - it brushes and vacuums right up so I'm not thinking it's algae but I've also never seen algae so I could be wrong.
    Here's MY plan (correct me if I'm wrong):
    1. Keep FC up today to shock level (20-24)
    2. When testing later tonight, I'll recheck the CC level. If still 0.5, great!
    3. When I check first thing tomorrow morning, if my FC loss is less than 1, I'll stop the slam. If it's not, then I keep going another day??
    Opinions? Encouragement welcome? This is my first time....
    18,000 gal; inground; vinyl; 18' x 36'; Cristal-Flo Sand Filter (new sand 4/27/15); Taylor K-2006 test kit; Avon, Indiana
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: My first SLAM...encouragement needed...
    Sounds like you are doing good. When you say stuff I the corners, is this on the floor as in it can be something that blew into the water or its on the wall?
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Yes keep your FC at or above shock level
    As long as CC stays where it is that is good and you want to make sure your water is crystal clear.
    If you do your last add around 7:30pm or so then recheck in 30 mins to make sure you are at FC shock level do not add anything and check in morning just as the sun is rising before pool gets direct sunlight to see if you held over night.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    You are doing the right things. You are almost there! The main thing is keep FC at or slightly above SLAM level as often as possible. Dont give up now!
    There are 3 criteria for completing the slam.
    1. CC = not more than one drop (<.5)
    2. You Pass the Overnight Chlorine Loss Test. (not more than 1 ppm loss overnight)
    3. Your water is perfectly clear. It may take a couple days for your filter to filter it all out. You need to stay at SLAM FC until its clear.
    Dont forget to backwash or clean your filter if the pressure rises 20-25% above the clean pressure. A clean filter will help the filtering go faster
    Dead algae looks like light brown dust on the bottom of the pool. If you touch it, it just desintigrates. If you have the dead algae dust, I would recommend to try and easily as you can vacuum it out.
    Divin Dave,
    May 2015
    Avon, IN
    23
    The stuff is not on the walls. It's in the corners where the walls slope to the deep end and brushes up like dust when I brushed it this morning. I disturbed all of it with the brush this morning and will vacuum later today again.
    My filter pressure hasn't risen at all. I've made sure the gauge is working properly (it's a new one and I took it off and put it back on last night to make sure it wasn't broken again). I'm watching it. It's about 9 and maybe normally sits at 8 so if it goes up again, I'll backwash... is that OK?
    I'm not sure exactly how clear this pool will get...so it sounds like maybe I should keep going for a few days to make sure the filter cleans it all up? Like how long is a typical SLAM when you are just slightly cloudy at the beginning? I was more hoping to stop the SLAM earlier rather than later (have 3 kids that think the water is 95 degrees!!) and then let the filter do its thing...so maybe I shouldn't do that and keep FC up for a few more days?
    Then after all this, I'll continue to adjust my pH.... right?
