Thread: Liquid Chlorine affect on PH
    Apr 2014
    Bakersfield, California
    24
    Had pool replastered about 1 year ago and been on TFPC method. Have always had problem with controlling PH (goes up). Went to Leslies to buy MA & Liquid Chlorine a few weeks ago and they said problem with consistent high PH is the use of liquid chlorine. They claim that liquid chlorine raises PH. Any thoughts?
    Here are current water chemistry readings:
    FC=4.0
    PH=7.5
    TA=60
    CH=300
    CYA=30
    20K gal colorscapes dark gray plaster, no SWG, BBB method, variable speed hayward ecostar pump, pentair cartridge filter, hayward navigator cleaner.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Liquid Chlorine affect on PH
    I disagree that it s the LC raising the PH. It may some, but I would say it is more likely because your plaster is so new from what I have read on here.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,186
    I disagree on the chlorine comment also. I would look more at your TA of 60, and maybe bring that up a tiny bit. I just brought mine up form 60 to 80 and I am putting in a lot less acid. I'm also letting the pH sit closer to 7.8.
    Support the site
    30,424
    The effect of chlorine introduced into a pool is a neutral change in pH.
    True, it initially has a pH of around 11.7 I think, but the change to HCl in your pool neutralizes that and results in no appreciable change in your pH in your pool water
    May 2014
    Franklin, NC
    9,186
    Did they make a recomendation as to what they wanted you to use?
    Support the site
    Aug 2014
    Shallotte, NC
    693
    Liquid chlorine does raise pH, because it is basic..... but then, so is rain. Typical Pool Store specious argument. I'd take a look at your TA. It seems a bit low.
    Your pH control issues are most likely from the replastering....
