Thread: How do you figure out how long to run your pump with an SWG???
    Aug 2014
    East Northport, NY
    155
    Thanks in advance!
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    30,431
    Re: How do you figure out how long to run your pump with an SWG???
    Trial and error. First bring your FC up to your target level with bleach.
    Once that's done you can adjust your SWG up or down depending on your daily testing of the FC.
    Aug 2014
    East Northport, NY
    155
    Ok thanks. Would there be an average you would think? 6 hrs, 8 hrs, 10hrs?
    TF-100 Test Kit
    Aquabot Bravo
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    The pump run time will depending on the capability of the SWG unit and whether your pump is single-speed or multi-speed, so this will take some experimentation. I would suggest starting with 4 hours of run time if your pump is single speed and 8 hours of run time if your pump is capable of running on lower speeds (i.e. two-speed or variable-speed pump). If this amount of run time is not sufficient to keep the pool clean enough for your preference, then gradually increase the pump run time until it is clean enough for your own tastes. During this experimentation time, I would test the FC at least daily. Twice a day testing would be better - once in the AM and again after the sun is no longer hitting the pool. I would also record these tests, including the dates and water temperature. Check out this article for more information on pump run times: Determine Pump Run Time
    Feb 2014
    Upstate, NY
    390
    I'm going through this trial and error now as well. I have a VS pump and run 11 hours a day. I had my setting on 30%. I'm now at 15 %. I have not yet dialed it in to where I want it.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Aug 2014
    East Northport, NY
    155
    Wow. I run my pump (single speed) without the SWG for 8 hrs a day just because I thought you were supposed to. The pool gets full sun so I am thinking if doing 4 hrs to start run from 11:30 - 3:30
    TF-100 Test Kit
    Aquabot Bravo
