Results 1 to 9 of 9
Thread: Solar pool covers
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    Solar pool covers
    Hey forum,
    Thinking about buying a solar blanket, cover, fancy bubble wrap for my IG pool. Curious, any experiences with the different mil sizes and have they ever blown away on anyone? I get some decent winds at my house and I don't want to see my new bubble wrap blow away...ha ha.
    How about increasing pool temps and helping evaporation? Does it really help?
    Does it do anything with chemical balance (PH, FC, TA, etc...) because this sheet of plastic is laying on top all day long?
    17x27x37 (24000 gallons) Lagoon Vinyl liner, Hayward Eco VS Pump, Hayward 4350 DE Filter, Auto Pilot SWG, Savi LED Lighting, Maytronics Dolphin M4 Vacuum
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: Solar pool covers
    Mine has never blown away. The temp increase can be substantial when your pool is in direct sun. It also keeps the heat trapped overnight it also helps reduce chlorine usage.. My clear heated things better than my newer blue. I would guess it added about 2 months to our season last year. I recommend a reel. The reel has been awesome.
    I also can't use it in the summer or the pool gets way too hot.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    Great, thanks for information. Any help with pool water evaporation? And for clarity, you like the clear type over the blue? What mil thickness do you use?
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    It does slow down evaporation, our new one is thicker so I'm really grateful for the roller. Get a roller for sure. The clear one seemed to warm the water a bit more.
    Apr 2014
    Stony Brook, NY
    159
    Quote Originally Posted by Defgufman View Post
    Sorry to jump in, but I bought the cheapest roller last year, and well....it blows. What roller you guys using?
    14000 gallon 16x32 roman in ground vinyl, Hayward 140k heat pump, swg, de filter 1 1\2 HP v.s. pump. Built in June 2014. Tf100 test kit.
    Aug 2014
    East Northport, NY
    155
    I have a clear 16 mil that has a prorated warranty. I am on my 3rd one and very happy with it. I also have a reel. You have to get a reel for it
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Ukie's Avatar
    May 2012
    Export, PA
    83
    Quote Originally Posted by mkmscr View Post
    Of course it helps. Have you ever seen how warm pool water evaporates when you use pool on a colder evening?
    I have a black one. It helps to absorb sun's heat. The only drawback is that I can't see pool lights when cover is on.
    Lagoon shape, 23,600 Gal, steel walls by International Swimming Pools, "ultra-seam" liner by Latham, Pentair 011018 IntelliFlo 3HP Variable Speed Pump, PentAir CCP420 filter, Heat Siphon Z575HP, PentAir IC40 SWG, 2 LED Lights (Pentair Intellibrite 5G, 110V). 4 x 1.5’’return lines, 2 x 2’’skimmer lines, 1.5’’ waterfall line. All plumbing is "TigerFlex" pipe, all lines plumbed individually. Deck: travertine glued over concrete.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I have a 12 mil blue. I cut it in 3 sections to handle better but wish I'd have cut in 4. It has helped save chlorine but doesn't warm much. I've noticed since I've been using it my CC stay at .5 Were always .0 before.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I bought a 16 mil clear but I knew from reading to get a reel for it... I purchased this one
    http://www.amazon.com/gp/product/B0037TWCH0
    It is very nice but I have not put it together so i cant say how good it is yet, sometimes that reel is cheeper elsewhere but I have prime and its free shipping so worked out close to the same price...
