Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: First Slam tonight. FC consumption!!
    May 2015
    Sherwood, AR
    28
    27,000 gal. 75F.
    ph 7.4
    ta 40ppm
    ch 190
    cyn 50
    fc/tc/cc 0.
    Calc 1210 oz (10 jugs) 8.25% bleach would get me to fc 30. Where I planned to get more in morning to maintain.
    Tested 2 hrs after application. fc .5 (if that). tc 20 (didnt scale test to read 30).
    Pool is a swamp, looking better around steps. Im now assuming this fc consumption 20/30 in 2 hours during night is possible with high contaminate.
    Contemplating how to proceed. Was going to identify/quantify shock on hand. Wondering what product I should try to continue the process with in the morning.
    Any Thoughts?
    30,419
    Re: First Slam tonight. FC consumption!!
    Welcome to the forum.
    Use liquid chlorine to SLAM your pool. You need a lot of it and the powder contain stuff you do not want in your pool. Bleach or liquid chlorine only and get it in right away. The idea in the SLAM is to constantly replenish your chlorine and yours has dropped back to nothing.
    Use the FC/CYA chart to calculate your SLAM value.....how did you get 30PPM?
    May 2015
    Sherwood, AR
    28
    I used the pool calculator, which stated fc 29 ppm for mustard algae, and reading through forum seems like everyone Slams at 30 ppm.
    May 2015
    Sherwood, AR
    28
    Ive tested again, FC and CC both are 0 now. So I tested again ph 6.8, TA now 30. BUT, as luck would have it, 1.5" of rain fell at some point which I drained.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum,
    Your FC level during SLAM depends on your Cya level. That's all there is to it. The goal is to stay at or just over SLAM value at all times until you are done with the procedure.
    Essential Links:
    May 2015
    Sherwood, AR
    28
    Ill heed the advise, but I have 5lb of 65% hypochlorite i considered throwing in the mix to get fc up. To my knowledge thus far, it would raise CH, which i held steady at 190. Another go x2, I will have spent c-note and have 30 empty jugs of bleach.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I hate you had to spend the money to clear it, but the only thing you can do it with properly is Free Chlorine. If you went to a pool store for everything, it would like cost you much more.
    You might be able to use the Cal-Hypo, but I don't know what kind of pool you have. If you would please, add that to your Signature, before posting more questions. List your pool details there please. That way, we know whether or not you need to be concerned with high CH levels. and we know the specs of your pool to answer further questions.
    Essential Links:
    May 2015
    Sherwood, AR
    28
    Thank you. Added signature, but stated everything in 1st post. Stated cyn 50, but meant cya 50.
    I digressed. I added 1210 oz of 8.25 bleach, expecting fc approx. 30. Tested in 2 hours (at night), it was zero. I was curious if initial dose could normally burn off so fast? Maybe CYA suspect? understand test can skew in cloudy water, but I expected about 50.
    I figure something will give. 1210 oz of bleach every hour or two is unrealistic.
    27k gallons, 18x36, Chlorine, Vinyl
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    What does the water look like? That is a lot of consumption, but I don't know what's in there. Sounds like a pretty bad swamp with that much FC consumption, or possibly ammonia. Either way, you're burning through FC, and until whatever is doing that is gone, it will continue. Is there a lot of debris in the pool? If you don't know, or suspect there might be, it should be a high priority to remove it.
    Essential Links:
    May 2015
    Sherwood, AR
    28
    Too, I dont mind spending money to clear my pool. So, dont be sorry.
    May 2015
    Sherwood, AR
    28
    It was nearly black with 8" visibilty. Now there is some light, I see visibilty is almost 3', and its lighter green now. No debris (no leaves, etc.). My suspicion of fc drop due to contaminate, is feeling confirmed. First time, didnt know what to expect. Ill attempt to raise and hold again.
    Thank you.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Just keep raising and hold FC at shock level as much as possible.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by GI Chuck View Post
    Thank you.
    Hey, no problem and that's ok. But that explains it. Heavy load with the black water, maybe more. This is going to take a lot of FC. I can't stress enough to clear out anything left on the bottom, old leaves or other junk. This really taxes your FC by placing a heavy load on it. AZgirl is right, just keep going to shock level and do your utmost to stay there. This is true for every SLAM no matter the condition. Barely cloudy, or Black like this one, Free Chlorine is the answer. Is there any idea how much junk may be on the bottom?
    Essential Links:
    May 2015
    Sherwood, AR
    28
    Just algae, and earth worms. I have no trees or leaves.
    30,419
    If you have algae settling to the bottom, you should vacuum that out (worms, too). Use your manual vac and keep an eye on your filter pressure. Backwash when psi shows a 25% increase.....you may have to do it often.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    The more stuff you have in there other than water, the more money you'll end up spending on bleach to dissolve it.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2015
    Sherwood, AR
    28
    Understood. I was planning to brush it down before bringing fc back up, but ill vacuum. Cant see the bottom. Although I cleaned the baskets prior, they fill with june bugs in the night. They are insane right now.
    May 2015
    Sherwood, AR
    28
    btw, my system runs at 20 psi fresh, and I backwash at 30. It shows signs of not liking being over 30 (just like me). Thinking I might pull the light off too.
    May 2015
    Sherwood, AR
    28
    wife just told me, as it sits I would need to vacuum to waste or risk damaging the filter.
  20. Back To Top    #20
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    If there is a lot down ther, I would vacuum to waste
    Lisa
