Thread: Intex pump to ground pump?!
    May 2015
    Canton/michigan
    2
    Can I buy a ground pump to use on my intex pool that has a pump that is attached to the wall of the pool? How do I switch it if so?
    titleistseemore's Avatar
    Jul 2014
    Lodi Ca
    189
    Re: Intex pump to ground pump?!
    I believe you are talking about a Poly Group Pool (Summer Escapes or Pro Series) Intex pools come with a ground pump. I have a read several forums here on how to convert from the skimmer pump to a conventional pump / filter setup. Here is a part you might be interested in ....
    http://www.amazon.com/Summer-Escapes.../dp/B004ZH50FE
    Here is a thread that might help you ...
    http://www.troublefreepool.com/threa...cape-pool-HELP!
    By the way welcome to TFP ...
    Tim Jacobsen Lodi Ca.
    18'x48" Intex Ultra Frame (5700 Gallons)
    TF 100 Test Kit, Speedstir, & Sample Sizer. Liquidator Installed.
    Hayward C550 Cartridge Filter (55 Sq. Ft.), 1HP Powerflo LX Pump, Pool Rover Jr.
    http://www.troublefreepool.com/threa...uild-Questions
    May 2014
    Norman, Oklahoma
    3
    My solution was a set of these..
    http://www.amazon.com/Intex-Pump-Thr...JKT1MWZ6K450MY
    And something like this..
    http://www.poolwarehouse.com/shop/sw...-inlet-outlet/
    This fitting didn't fit perfect. It was a little small on the OD of the fitting compared to the hole in the liner but did not leak at all. Bought them locally at the pool store and added a real pump.
    Best thing I ever did was add a proper pump that allowed me to run a Kreepy Krauly suction side pool cleaner.
    Good luck!
    May 2015
    Cape May/New Jersey
    30
    Sorry to hijack the thread...
    Is this question the same as using a Hayward sand filter and pump instead of the supplied Intex pump?
    Jul 2014
    Lodi Ca
    189
    An intex fitting will be 40mm threads, Standard pool equipment like a Hayward will use 1 1/2" threads. There has been allot of posts on how to convert and some different ways of accomplishing the task. Below is a thread you might find useful for an intex to standard pool equipment install. The links provided from Joe would also be useful ...
    http://www.troublefreepool.com/threa...or-Intex-Pools
