Results 1 to 12 of 12
Thread: Looking for energy efficient replacement motor
    May 2015
    White Pigeon MI
    6
    My motor is screaming at me and I'm planning on replacing it with the most energy efficient option that still functions well. The pool is 18,000 gallons. Would you guys recommend a 2-speed? Here is a pic of what I have now: Pump motor.jpg
    May 2015
    White Pigeon MI
    6
    Re: Looking for energy efficient replacement motor
    Any recommendations?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Welcome to TFP
    A two speed, if you run it in low speed a lot will be more energy efficient but we will need to see more information on you set up. If you could add your pool details to your signature we can take a looke at it. Type/size of filter, or other details like waterfalls, returns and sheer descents may effect it.
    Support the site
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Please update your signature as shown here.
    May 2015
    White Pigeon MI
    6
    Signature added. Am I missing any critical info?
    18,000 gal, AG steel wall/vinyl liner. One drain, one skimmer. Installed in 2008.
    Filter - Pentair FNS Plus Vertical Grid D.E.
    Pump - Pentair SuperFlo 3/4 HP, 230V self priming, single speed
    Aqua Rite Electronic Chlorine Generator, Turbo Cell
    Dolphin dynamic cleaning robot, auto cover, no water features
    May 2015
    White Pigeon MI
    6
    Again, I am looking to replace my pump motor and would love any input on what you guys would recommend or do in my situation.
    May 2015
    White Pigeon MI
    6
    Any pump experts here able to chime in?
    Bob_Funk's Avatar
    May 2009
    Seattle-It really rains all the time
    113
    I'm no expert but I just installed a Pentair wisperflo 1hp 2 speed on Saturday & I like it so far FWIW.
    I consider myself very lucky I found this site before the pool store found me-pool owner since Nov 2008- Stunningly clear 17,000 gal fiberglass pool, thanks to this site, installed in 1982-24" 3.1sq. ft sta-rite sand filter, 1 hp - 2 speed wisperflo pump-WFDS-4
    DFW, TX
    24,502
    Seems like a 2 speed version of what you have would be good.
    May 2008
    Northern California
    73
    Maybe someone can confirm, but it appears the Century B2980 motor would work. It has the same physical specs (56Y frame size, square face mounting). The only part that doesn't match is the total HP; your existing pump is .98THP and the B2980 is 1.25THP, but I believe it's okay to run a higher HP motor with your existing impeller and not the other way around. I have the larger Century B2982 and it's great. There is also the B2980T which has a timer.
    Make sure to get a new seal and I like to replace the o-rings too.
    12,000 gal. IG Colorquartz, 1.65hp Sta-Rite with 2-spd motor, 300sf cartridge, disabled SWG, AquaLogic P4, Polaris 280, gas+solar, 6' sheer descent with dedicated pump
    May 2015
    White Pigeon MI
    6
    Thanks!! That looks like it may be the answer. I read somewhere that I may need to be careful with the pressure because I have a DE filter. Is there any reason to believe that it would not be okay to run a pump on low speed because of this?
    DFW, TX
    24,502
    Yes, bignick has that right, no worries runnin that pump on high or low speed.
