Results 1 to 9 of 9
Thread: Most Bang for your $
    Jan 2015
    Puyallup, WA
    50
    Ok we are getting closer in setting up our 20 x 52 Intex. Concrete pad is being poured next week then we should be good to go. The intex pool we have is the Metal frame 10x20 not the ultra and I have a question regrading the feet. How far do the feet stick out from the the 10x20 dimensions? Am I safe to assume about a foot?
    As far as most bang or your buck ideas. The pool comes with a sand filter already.
    Thanks
    Casey's Avatar
    SW PA
    10,461
    Re: Most Bang for your $
    I'm sure someone will be along to help you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    I don't know the answer, but maybe the pool install/owners manual is available on the Intex website and will have the details. If you already have the pool then it might be worth your time to unpack the upper rail parts and put it together to double check measurements. It is pretty easy to do on an Intex pool. Congrats on the new pool!
    Here is an Intex useful link thread somebody started a while back.
    http://www.troublefreepool.com/threads/28539-Useful-links-for-fellow-Intex-Pool-Owners
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    I don't see that size pool listed on the intex site. Please clarify. Is it 20' round x 52" deep, or is it 10' by 20' rectangular 52" deep? I find a 9' by 18' pool. If that's the one you have, this thread has your answer.
    Jan 2015
    Puyallup, WA
    50
    This Intex was sold by Costco so it will be an unusual size as most items sold by Costco will be just a little different. Our pool is 10x20 Rectangular in size. Information says 6 feet of extra room on all side but I know it doesn't take that much room thats just a standard.... We are trying to squeeze into a tight place but pretty sure it will work.
    Thanks
    Thanks
    Jan 2015
    Puyallup, WA
    50
    Perfect the link had the info that i Needed even though it's for a 9x18 I just i added my additional dims and I will be good to go. Now to the most bang accessories for the pool. Where does everyone buy pool floaties, etc stuff at?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,198
    Quote Originally Posted by octanefam View Post
    well, where did you get the pool...... I get my floaties at Costco!
    Glad Richard had the link for you!
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I get my floaties from Amazon
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    19,073
    Well, when it is set up and full, break out a tape measure and doublecheck things and post the info. That way you will add to the store of knowledge here.
