Results 1 to 14 of 14
Thread: Replacement Compupool unit bit the dust after 1 season, back to bottle service
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Opened the pool this season, water tested ok, but salt was a bit low. Put in 3 bags to bring salt up to 3800.
    I noticed the front display being warmer than usual, but the heatsink seemed normal.
    This morning I checked on it, and display was dead.
    Opened it up tonight, and found parts on the bottom of the case melted to the case.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Replacement Compupool unit bit the dust after 1 season, back to bottle service
    What model is that? Was it in service when it did that? Is it a new cell or controller?
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    They sent me a replacement for my original unit which almost melted the wires to the cell.
    This is the latest CPSC48 with the new cell.
    I got it in time for last season (had to go half the season of 2013 without it because they didn't have any replacements in stock). Worked fine last year, but this year decided to go belly up.
    At this point, I have no confidence in their units. I'll have to look at some better brands, I'll never buy them again.
    K-2006 Test kit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That sucks. Is it not still under warranty? I have a Si-60 plus on order now.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    It might still be under warranty, it's right at 3 years from the original purchase, and this unit is only 1 year old.
    No faults were shown, it was originally set at 50% power, then i reduced it to 40%
    tested my water tonight
    Salt: 3800 (taylor K-1766 test kit)
    FC: 3.0
    Ph: 7.4
    TA: 30
    Ch: 125
    CYA: 60
    K-2006 Test kit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Surely they would do something about that. That's basically a catastrophic failure. Either way, that's a bad situation to have electrical components melting, especially around a pool.
    Jul 2014
    Peoria, IL
    389
    I am sure compupool will take care of that. Being only a year old and all. I have been lucky (looking for wood to knock on) with mine. This is our 4th year with our cpsc24. But as I haven't hooked it up yet for the year I am going to keep my mouth shut and hope that they do right by this one. Good luck.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Give Jason a call at Compupool. He's been very helpful with my issues. I ended up going with a CPX series. (It had 1 issue required a new power supply, but has been ok since.)
    Jason Thompson
    Customer Service Manager
    CompuPool Products
    126 Semoran Commerce Pl.
    Suite B
    Apopka, FL 32703
    Toll Free: 888-989-7258
    Fax: 407-880-6483
    compupoolusajt@aol.com
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    To date, they have not sent me a replacement unit. Last message I got from them in June, they said 2 weeks max.
    I checked their BBB report, it's not good. I filed another one today.
    K-2006 Test kit
    Aug 2014
    Shallotte, NC
    693
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    What should my next one be? Hayward? My mom got one of those, and she had something melting on hers too. At this point, I don't know who to turn to.
    The model pictured above is the new model, the CPX48
    K-2006 Test kit
    Apr 2011
    Murrieta, CA
    2,360
    When I have to replace this unit, if it's the power supply I'm looking at the aquarite. Known issue with current limiter. Easy fix.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Well well well, look what came in today
    K-2006 Test kit
    Apr 2011
    Murrieta, CA
    2,360
    Nice
