Results 1 to 15 of 15
Thread: Efficiency of T Cell 15
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    In a perfect world, if you had a 40,000 gallon pool and were able to keep the PH, Aklalinity and CYA etc perfect, would the Hayward T Cell 15 be able to keep up at 50% (50P) running the pump 8 hours a day? Everyone on here talks about how it is a good idea to oversize the T cell and I understand the reasoning, that it doesn't have to work as hard but just asking about what it is supposed to do if everything was perfect. Would 50% run time be enough or 75% at 8 hours a day from say 10 in the morning to 6 when the sun is the highest or most intense?
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Feb 2014
    Upstate, NY
    390
    Re: Efficiency of T Cell 15
    I'm not sure your question can be answered with 100% certainty ? Every pool is different and so are the requirements of each pool. Your pool is 45,000 gallons so a T15 cell would right off the bat be inadequate as per the recommendation here. Pump run time and SWCG time need to be dialed in based on your pools needs. Simply put, its trial and error until you have it where you want it.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Donny hit it on the nose. I like to say each pool is like a finger print, unique. Bather load, water temp, hrs. of sunlight, contaminants that get into the pool along with proper pool chemistry play into the % setting.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jun 2011
    Long Beach, CA
    2,778
    The math computes that at 100% running 24 hours a day the T-15 cell can produce 3.9ppm of FC in a day for your 45,000 gallon pool. This may or may not be enough chlorine for your pool depending on time of year, swim load, chemical balance, etc. Average pools use 2-4 ppm of chlorine a day during the summer months.
    During the peak swim months I'm guessing that you might need to supplement with bleach every now and then.
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    In my experience I wouldn't expect it to be able to keep up with a pool that large.
    I keep a tight reign on water balance and keep my 20k gal pool clean; bather load is light (just the two of us here). During the summer I usually have to run the T-15 10-12hrs at about 50-60% to maintain 6-7ppm FC (CYA at 80).
    Quote Originally Posted by ping View Post
    And at that rate I'd expect the cell wouldn't last very long.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I keep the CYA low at about 30 - 50% and have two Nature 2's in line. It kept up fine last summer without the Nature 2's and I was running it at about 75%. Would check water in early morning and would be 2-4 ppm. This summer, I am hoping to be able to run it at lower percent due to having the Nature 2's.
    38,251
    If you raised your CYA, then the SWG would not have to work as hard. Although using a Nature 2 is not recommended. We definitely do not recommend the mineral packs and they would not lower the required FC level anyway. And if you are use the trichlor, that is going to continually raise you CYA, which for now you need, but later you may not.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I don't use Trichlor. I have a Haywood T-15.
    Nature 2 claims to lower the required amount of FC. They claim you can lower it down to 0.5 ppm. Personally, I question that but will find out. Any lightening of the load on the SWG would be a plus anyway. Why would I want a high CYA? That would just require a much higher FC ppm to avoid algae.
    38,251
    Well, their claims are bogus. It may help lower the odds of algae, but it is the chlorine that is required to protect you from disease transmission. And all the minerals put you at risk for green hair and staining the pool.
    The higher CYA means you will actually lose less FC to the sun, even though the absolute FC level is higher.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Water Balance for SWGs
    And this is a good read too regarding the minerals:
    The Truth about Alternative Sanitizers
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    The nature2 adds copper and silver to the pool to act as an algaecide, which the pool stores will tell you lets you run a lower FC. Algae isn't growing, but other bacteria and pathogens can with the lower FC. Higher CYA levels, as recommended for SWG users, protects more of the FC that your SWG is generating. You have a higher FC level, but not as much gets burned off by the sun through the day.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Feb 2014
    Upstate, NY
    390
    Quote Originally Posted by Saturn94 View Post
    Interesting. I run my pump 11 hours a day and I'm at 15%, maintaining 5 ppm FC.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I agree that mineral systems are a supplemental sanitizer and will not sanitize the water completely but they do help. Also, I agree that there are only three sanitizers - chlorine, bromine and biguanide. Of the three, chlorine is the best and the most economical. Natural minerals, however, such as silver and copper, have been used for thousands of years to effectively control bacteria, algae, and other harmful contaminants. A residual sanitizer is needed, in a pool, that has a fast kill time. Chlorine is the best alternative and a salt water chlorine generator is a great way to supply that residual sanitizer. I'm just trying to use a blended system.
    I'm under the impression that lower CYA levels promote better FC effectiveness. People who follow the TFP principles want to preserve as much chlorine as possible and would probably want higher CYA since they may be skipping a day since they last added any chlorine. With a SWG, I am putting chlorine in the pool during the daylight hours when the sun is up. A good analogy is a comparison to treatment for Diabetes. In the past and now, people gave themselves shots each day to keep their insulin under control. There would be ups and downs. Now, there are new treatments and implant pumps that allow the insulin to be given in a measured dose all day instead of in one shot which avoids the large swings in blood glucose levels. The comparison to SWG insertion of chlorine in measured doses is obvious and is the reason that people say salt water pools are superior. In public pools, obviously, there have to be laws governing the type of sanitizer used but in private residential pools there are no laws. I am just trying to find the best system overall.
    This is a great website and resource. The TFP methodology is solid and is a great system that helps to develop and promote a simple, inexpensive, and effective system of pool care.
    38,251
    The FC levels we recommend are what is needed for the water to be safe regardless of mineral content.
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    Quote Originally Posted by Donny View Post
    There have been times I've been able to get away with setting as low as about 30%, but that was with a new cell and keeping FC borderline low (This was before discovering these forums).
    Perhaps being at a lower latitude and all day sun explains why we lose more FC?
    PS - I just replaced the cell today. The last one lasted 7 years, so I can't complain. We'll see what settings I end up with (waiting for CL to drop to normal after the spring opening SLAM....today's FC is at 14ppm).
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    In my experience metals + SWCG = stains (unless you keep a sequestrant in the water)
    I learned the hard way.
