Results 1 to 7 of 7
Thread: plumbing question
    Jun 2014
    Hauppauge, NY
    19
    plumbing question
    Is there an benefit to running separate lines for each pool feature. See my attached rough sketches.
    20 x 40 Inground Liner Walled Pool 33,000 Gallons, Hayward DE3620 Filter w/ multiport valve, Hayward SuperPump VS Pump. Stenner Fixed Rate Chlorinating Pump
    4knights's Avatar
    NE Kansas
    419
    Re: plumbing question
    I did individual ones to mine for the return and skimmer- you MUST connect the main drains (if more than one)to each otherwise you Must connect main drain to the skimmer.
    Law based on entrapment hazard and drowning (Virginia Graeme Baker Pool and Spa Safety Act).
    I would add more returns as you want to move the water avoiding dead spots. I have 4 returns and wish I would have added at least 3-4 more.
    The individual lines can be shut off if they break or can be converted for cleaner use.
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jun 2014
    Hauppauge, NY
    19
    Where would you add returns? I'm not quite following on your statement with the main drain. I have 1 main drain whose plumbing line goes straight to the filter pad on its own valve.
    4knights's Avatar
    NE Kansas
    419
    I edited my reply^
    The skimmer has a fitting on the bottom to connect the main drain to it.
    If you are just building this pool then put in 2 floor drains- 1 each side connect together then to pump .
    I would put the Return lines where you have them as well as at least one on each side, either in the middle if single or split distance on each side if adding 2 per side.
    They allow you to direct flow of water on top to skimmer, as well as directed to ensure mid and bottom levels are moving
    4knights's Avatar
    NE Kansas
    419
    Not exactly like this but it's a good picture to show flow
    Jun 2014
    Hauppauge, NY
    19
    Pool is existing, it was installed 20 years ago. I am new home owner an am installing a new patio so while it's all open I will be replacing the underground plumbing with rigid 2".(currently flex 1.5"). This is where I have my dilemma as far as how to replumb. Adding 2 new returns may be too much of a pain but I should be able to add 1 new return in the deep end since one side of pool will be trenched. My next question is with main drain. Can I replumb this without plugging the line. I don't have scuba gear so I don't see how I can plug the line to stop the flow of water once I cut the pipe to replumb. I'm still deciding whether to do this myself or hire it out. My issue with hiring out is both pool plumber guys I have gotten estimates from want to do the job half assed.(1.5" pipe and connect everything together) I don't relish the idea of trenching myself though
    4knights's Avatar
    NE Kansas
    419
    There is nothing wrong with connecting the lines together, it's based on your preference and future planning. 1.5 inch pipe is acceptable and you can tell the plumber that you want 2 inch rigid. They use flex because it's easier for them. ( you're paying, so get what you want)
    trenching isn't hard, but it isn't easy either! IT IS Dangerous if you don't know what your doing.
    I wouldn't make any permanent decisions until I had the water level down to my planned working height, then trench ( call dig safe first!). Then decide on how to proceed. If it's 20 years old, that explains the not having 2 drains or not connected to skimmer.
    I'm not a plumber or pool builder- just a DIY guy.
    Are you partially draining the pool or ?
    You don't have to remove the drain unless you can't remedy the entrapment issue, if you have access to the skimmer and are re plumbing it, you could connect the drain to it.
    I would think that cutting the drain line as high as possible (close to water line) as well as putting a weighted upside down bucket over the drain, you might be able to tie in without losing to much water. I would only do this after skimmer tie in was complete and ready to accept drain tie in.
    The bucket my thoughts - (rubber bowl larger than drain) or any brand 5 gallon, add a towel or cloth of some sort to the lip. Then get in pool and put bucket or bowl over drain, set a concrete block on top of bucket. Complete skimmer tie in, cut main drain and connect.
    Sounds way easier than it may be, or it might be a snap. Honestly you won't know until you get there.
