Results 1 to 10 of 10
Thread: TFPC Method - Season 2 opening....I'm officially sold.
    May 2014
    Ohio
    75
    Well guys as the title says, I am now sold on this method. I have to admit I was a skeptic last year after going through an entire tf-100 kit and about 80 gallons of bleach trying to complete my first SLAM. I literally took my cover off at 4 pm today, about 3 hours ago and after 1 vac to waste, this is where I am at.
    Attachment 36176
    As you can see, I have another issue(sand)....but that's another story. Water is about 90% clear and my initial readings are FC 2.0 CC 0 and pH 7.2. In 12 years of opening this pool, I have never been able to see the main drain. Kids asked me when they could swim, I initially said middle of next week. Guessing that may change. Thanks everyone.
    16' x 32' Hopper IG Vinyl | 19,000 Gal | Pentair Tegalus 60 Sand Filter | Pentair Challenger 3/4 hp Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: TFPC Method - Season 2 opening....I'm officially sold.
    Excellent!
    I suggest you teach those kids how to run the vacuum and the brush. And if they happen to fall in....
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    That is great! Check your CYA and add some bleach to get to the recommended level of FC. Sand ISO much fun...lol not really I have learned to just deal with it and if I see anything else other than sand I vacuum.
    Excellent!
    I also agree with Richard. My daughter loves to help.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Super!
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Beautiful Styx!! Good job there!!
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Very nice. I put a plus size nylon in my Polaris bag and it grabs all the sand now. If you have one, try it out. It has reduced my vacuuming to zero.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    May 2014
    Ohio
    75
    How often do you run the polaris? They had one when I moved in, but everytime I used it, it got stuck in deep end.
    May 2014
    Ohio
    75
    Not sure if anyone is reading this anymore, but quick question. The first day, I overshot my mark in the bleach department. It went up to twelve. That was Friday night. Checked it again on Saturday morning, it was at 11. Left for the weekend. Came back Sunday night and tested, it was at 8. This morning, it was 7. Do these numbers seem reasonable? Just looking for confirmation either way. My CYA is 50 so my target is 6. Water looks great. Is slamming generally an annual thing, or do I skip it? Thanks in advance.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    They seem reasonable to me. You will lose 1-3 ppm a day generally to uv rays from the sun.
    Lisa
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Those numbers look very reasonable. With no bather load, FC loss should be 1-3 FC per day. Your numbers look great.
    SLAM is not an annual thing. Generally after opening and getting the dirt, leaves out the pool in the spring it's a good idea to bring your FC up above your target by a bit and do an OCLT test (the last step of a SLAM) but if your FC is holding and you have no CCs, no visible signs of algae then it's not necessary to SLAM.
    Isolated Spa - 345 Gallons
