Results 1 to 11 of 11
Thread: Question on my first SLAM
    May 2015
    Chesapeake, VA
    14
    So I opened our pool about a month ago. Lately I've been seeing little areas in the corners of the pool on the floor that look like sand/dirt. When you brush them they dissipate and later come back. Appears it's mustard algae.
    So yesterday afternoon I bought 12 gallons of 8.25% bleach (121 oz each). Before putting anything in the pool my CYA was 45-50 and FC was 0. Here's a list of my steps:
    SWG OFF, filter on
    5/7 7:00PM added 6 gallons of bleach; brushed pool
    5/7 8:00PM FC=25, CC=1
    5/7 9:30PM FC=23.5, CC=0.5
    5/8 6:00AM brushed pool and vacuumed up mustard algae
    5/8 6:00AM FC=22.5, CC=0.5, then turned SWG on at 100% and went to work
    5/8 6:00PM FC=16, CC=0.5, still had some algae in the pool so I brushed and vacuumed again
    What I don't get is how overnight I lost very little FC and my CC was under 1. I left the house this morning with FC at 22.5 AND my SWG on 100% all day. How could I come home and FC be less than when I left? I understand the sun dissolves some of it, but it was fairly cloudy today. I find it hard to believe that my FC would drop 6.5ppm while the SWG was also running at 100%. That means I probably really lost 8-9ppm FC during the day today. But what throws me off is that CC is still basically 0.
    Should I add more bleach?
    20,000 gallon pool with liner
    Hayward DE6020 filter
    Pentair IC40 SWG
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: Question on my first SLAM
    Don't run your SWG during SLAM. You can have 0 CC and still have something going on. Just keep adding bleach to shock level until you pass OLCT, your pool is crystal clear and your CC is 0 which you already have. When adding in the morning overshoot your FC shock level since you don't add again until evening. I would overshoot it by 4-5 ppm tomorrow and see what happens.
    Also it am not so sure it is mustard algae. How does your water look right now? It could be pollen or may just be sand too
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,989
    Sunlight uses some of that FC. And algae grows in sunlight, so there is more to kill off during the day, which uses more chlorine. You still see some, so it's growing. SOunds normal to me, Keep the FC up and keep brushing. You need to disturb the slimy scab the algae grows to protect itself so the chlorine can get in there and kill it. And do not neglect ladders and steps and lights. They provide good hiding places.
    May 2015
    Chesapeake, VA
    14
    Our water has been crystal clear. We had this stuff last year too but rather than actually get rid of it I would vacuum it out. It's not a whole lot, a spot here or there. But it's annoying to constantly have it there.
    Pentair IC40 SWG
    May 2015
    Chesapeake, VA
    14
    So after passing the OCLT, what's next? If tomorrow morning my FC is unchanged at 22ppm (I added a gallon of bleach a little while ago), water is clear, and CC is 0 will FC gradually just make its way down to somewhere near 5 and level off? Just trying to think how that will be possible if I have my SWG going and assuming that negates the lost FC due to sun. Should I not run my SWG until FC comes back down to closer to 5-7?
    Pentair IC40 SWG
    Aug 2014
    Northern IL
    4,615
    Did you retest after your addition tonight to know your actual FC/CC numbers?
    May 2015
    Chesapeake, VA
    14
    Yes, FC 22.0 and CC 0.5 (really probably closer to 0.0, it was the faintest pink and one drop completely cleared it).
    Pentair IC40 SWG
    Aug 2014
    Northern IL
    4,615
    Great. Retesting after additions on an OCLT is often overlooked. Good job, and good luck!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by MarianParoo View Post
    Or any add in the beginning of the SLAM when you are not sure if your bleach is full strength or no... MarianParoo recommended I do this during my SLAM and it was not until I did that I discovered mine was about 1/2 strength. Once I actually did it things moved much quicker.
    Lisa
    Aug 2014
    Northern IL
    4,615
    Loves!!! The WRENCH!!!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Lol I knew you would.
    Lisa
