Thread: my pool is green with fresh fill
    May 2015
    bethalto il
    1
    I have a 4ft x 20ft intex style pool with a salt water filter. I just filled it, no well water, and its clear but has a slight green tint to it. I went to the local pool store and he had me put 2 bags of shock in it. Nothing has changed. Was wondering what else I could try.
    Thank you in advance for any help!!
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: my pool is green with fresh fill
    Can you update your signature with your pool and equipment info?
    Do you have a recommended test kit?
    We need a full set of numbers from a recommended test kit to better help you.
    We need:
    FC
    CC
    PH
    TA
    CH
    CYA
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Welcome!
    I'm assuming it's crystal clear, but some shade of Emerald Green? Odds are, it will go away in a day or two unless you filled from a well or a pond or something other than a municipal water supply. It's probably some rusty water that looks pale yellow normally, but against the bluish pool, looks green.
    If you just go ahead and balance it as if it weren't green, it should disappear. It's a common problem. Check the search function and see for yourself.
    And now, let's address the pool store advice. Did they perform a free water test? Did their expensive "shock" do anything? Odds are yes and no, respectively. Let that be a lesson.
    My immediate suggestion is to relax and see what happens to the tint. While you're waiting, peruse Pool School, especially the ABCs, Test Kits, Recommended Chemicals, Poolmath, and Water Balance for saltwater pools. If it's not too late, hold off on the salt until you get things straightened out and hold "Diamond Day" Post 5
