Results 1 to 14 of 14
Thread: Does anyone know what this is on my pool plaster surface??
    May 2015
    Gilbert/AZ
    7
    Hello,
    I am new to the forum. This place is great and I am hopeful to get some great advice.
    I will start with my latest test results. I added two gallons of liquid chlorine yesterday so it is still reading high.
    FC 10.2
    TC 10.8
    PH 7.2
    TA 91
    Hardness 271
    CH no info
    CYA 60
    I am also pretty new to owning a pool. Our pool sat empty for a couple of years after we bought the house. It was in pretty bad condition. We decided to get it up and running for some fun in the sun this year. We hired a contractor to chip out the old plaster, repair some cracks, and then re-plaster with a white plaster. Everything went pretty good. When the contractor was done he put the hose in the bottom of the deep end with a towel wrapped around the end of it. It took about 24 hours to fill.
    I was instructed to brush it twice a day for the first week and then once a day for the following weeks and run the pump non-stop until the pool gets clear. I was not given any instruction on what to do with the chemistry of the water. So, I went ahead and brushed the pool as instructed. I searched online for instructions on how to open a pool with new plaster. I opted for the traditional route. If i remember it involved a lot of brushing and vacuuming with a vacuum brush. It was important to use a vacuum brush so the wheels do not compact the plaster dust. Okay, a couple of days go by and the bottom starts to come into view. There was some back-washing involved. I kept an eye on the pressure gauge and back-washed after the needle crept up from 10 to 16 or 18. I also added 64oz of Beautec scale controller. Enough for an initial treatment of 21k gal. I added 5 lbs of CYA and started adding acid. I added two gallons of chlorine but I think it burned off pretty fast because there was not enough CYA. It was still the middle of March so it was not quite hot yet. I probably benefited from the lower temps. I was going to a couple of different pool stores and buying all kinds of chemicals. I know the ph got away from me for about a week or 10 days. I would add 1/2 gal and it would still read high. I would add 1/2 gal the next day and it would still be high. I finally bought 3 cases of acid. I would add 1/2 gal in the morning and 1/2 gal in the evening if it needed it. I just recently got the ph to a normal level.
    So, I know the pool was opened poorly. And that brings me to my question. The plaster developed some discoloration over several weeks. I cannot say for sure when it started showing up. I didn't think anything of it because it looked so awesome when the guys finished with it. It was really spectacular. A very brilliant white. Anyway, my wife pointed it out to me and I started to keep an eye on it. It was getting worse. I am now more than concerned. The water is crystal clear and you can see each grey splotch. It is mostly concentrated in the deep end. I have been doing some research and that has left me lost. Any help would be greatly appreciated. I have a meeting with the contractor set for Monday.
    21K gal diving pool with white plaster, IntelliFlo VS pump, 36 sqft DE filter
    Jul 2011
    Arizona & California
    803
    Re: Does anyone know what this is on my pool plaster surface??
    Please test your tap water and post the results for pH, alkalinity, and calcium hardness.
    Try to feel with your hand the dark gray areas to see if they are rough to the touch and different than the white areas.
    Did you add any chemical that contains copper such as an algaecide?
    When was the pool re-plastered?
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    What test are you using?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Looks like metal staining.
    when I bought my home last september the pool looked nice but the PH was very low...like 6.8
    after adding 45 lbs of ph up over a period of two weeks, to get it to 7.5, I started to see what you have.
    Everything I've read here indicates metal staining. I still haven't done anything about it.
    in hindsight I should have just done a bunch of partial drains and refills. My tap water has
    perfect for tfp pools PH & TA but lacks calcium and cya (of course)
    Dolphin E10 Cleaning Robot.
    May 2015
    Gilbert/AZ
    7
    Thank you for your reply. I am using a 4 way Oreq test kit. The TK400.
    Thank you for your reply. I am using the 4 way Oreq test kit. The TK 400.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by codyS View Post
    I recommend getting one of the recommended test kits if you can.
    http://www.troublefreepool.com/conte...its-comparison
    Lisa
    May 2015
    Gilbert/AZ
    7
    I tested my tap water. Here are the results.
    ph 7.6
    CH 220
    TA 110
    I rubbed the wall where some of the discoloration was and I could not feel much difference in texture. I have not added any algaecide that contains copper. The pool was replastered March 17th of this year.
    I noticed some water got into my pool light enclosure. Could that be introducing metals into the water? I'm not sure if the discoloration was happening before the light was compromised.
    Also, when the guys showed up to do the work they looked a little tired. They said it was their 3rd pool to shoot that day. Is that normal? I fed them a bunch of pulled pork sandwiches to help them out. I figured it would help them do a good job if they got something to eat beforehand.
    May 2015
    Gilbert/AZ
    7
    I will check out the test kits from the link. I am sure to need a new one soon.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I love my TF 100 and speed stir. There is a direct link to it in my signature. You get more bang for your buck and it is easy to use.
    Lisa
    May 2015
    Gilbert/AZ
    7
    The link is broken but I found it via Google. That is a sweet test kit.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thanks I will have to fix it.
    Lisa
    Jul 2011
    803
    Have you added a lot of acid, like more than a gallon at one time?
    I should have also asked you to take a plastic bottle with a squirt top, put some acid into it, and then squirt the acid underwater on the gray discoloration.
    If it removes the discoloration quickly, it is a metal stain. If the gray is not removed, then it is probably gray mottling discoloration of the plaster itself.
    May 2015
    Gilbert/AZ
    7
    The most I added at one time is 1/2 gal. I pour it into a bucket with a couple gallons of water and then pour it along the edge of the deep end.
    I will try and squirt the gray area with the squirt bottle and see how that goes. I read about gray mottling. I am really hoping that it is not gray mottling.
    Jul 2011
    803
    I should have mentioned that there is another way to test to see if the discoloration is copper staining, which color is usually blue/green (turquoise) and sometimes black.
    A popular method on TFP is to use Vitamin C tablets that are placed against the discoloration and waiting only a minute or two to see if the stain is removed.
