Results 1 to 14 of 14
Thread: Spa still losing water overnight after replacing check valve
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    I recently replaced the Jandy check valve to stop the spa from leaking down overnight with pump off and it did not fix it. Would one of the Pentair valves be the culprit or do I need to look elsewhere?
    I have attached a pic of my equipment pad.
    Thanks
    Bob
    [/URL]
    32 x 15 15500 gal. IG gunite, 6 ft. round attached spa, diamond brite 2 plaster, flagstone coping w/concrete spray deck, IntelliChlor IC-40 SWG, 2 hp Max-E-Pro pump, 450 sq.ft. System 3 cartridge filter, 400k Max-E-Therm NG heater, automation is IntelliTouch i7+3, Polaris 280 pressure side cleaner,
    TS 100, Borax
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Re: Spa still losing water overnight after replacing check valve
    Quote Originally Posted by bware View Post
    Thanks
    Bob
    [/URL]
    Bump
    Anybody?
    TS 100, Borax
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    I don't know much about equipment bump will bump you again
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I'm assuming the line on the left is the spa circulation, the middle is the pool return and the right is the spa return?
    Its hard to tell from the picture but it almost looks like the check valve flapper is upside down...it may just be a reflection though but worth looking into?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Quote Originally Posted by Azgirl71 View Post
    thanks, Azgirl
    TS 100, Borax
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Quote Originally Posted by bdavis466 View Post
    Yes, the line on left with Jandy check valve is the spa return and I replaced the valve the same way it came out with the flapper on the top and silicone dressing on the o-ring for a good seal. I could not see any wear or stress on the old one, but I understand they can lose spring tension with age and leak, but evidently this was not the problem with my leakdown.
    Thanks for the thoughts.
    TS 100, Borax
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    If the spa is still draining, the only thing other than the check valve that is suspect is the three-way valve. I would highly doubt that the valve is the issue but at this point it may warrant an inspection.
    That check valve orientation is far from ideal.
    -Brian-
    POOL BUILD
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Yes, the 3 way is my thought, but what is your idea of the ideal check valve orientation? This is the way it's been for 9 years and I've seen many in this same configuration.
    TS 100, Borax
    May 2015
    Central Illinois
    41
    please forgive the naive question, but how do you know it's not a jet on the spa itself leaking?
    Viking Maui 2300g fiberglass in ground pool in a screened room with polycarbonate roof. 45gpm pump with sand filter manually chlorinated. Entire pool water can cycle in 51 minutes. Jacuzzi 336g hot tub with ozonator, manually chlorinated. TF 100 test kit with speed stir. Fungi pronounced Fun Guy, I'm Jim
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Quote Originally Posted by Fungi View Post
    Not naive at all, Fungi, but the water is ONLY leaking down to pool level and not as far as the jets.
    TS 100, Borax
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Horizontal with the lid facing up is the preferred orientation. You are correct, your configuration is very common, but you are primarily relying on the spring pressure to close the flapper and keep it closed.
    I still suspect your check valve is not seating properly.
    I would replace the tee with a three port valve so you can control the flow to the spa, place a check valve horizontally and then use an elbow to route the pipe down to your spa return line. With your plumbing set up, I don't think this would be all that difficult, although you would have to dig down and reposition the spa return line.
    -Brian-
    POOL BUILD
    bware's Avatar
    Apr 2015
    The Woodlands, TX
    77
    Well, Brian, I appreciate your input. I am certainly not a PB, but the one that put this pool in has built many and of course when I hired him I put my trust in him to make the right decisions, plumbing included. I can't get past the fact that I've only had this particular check valve replaced once about 5 years ago, in the same configuration and the spa has not leaked down again until now so I'm reasonably sure there is some other culprit responsible that is yet to be discovered. Thanks again for your input.
    Bob
    TS 100, Borax
    wjr75's Avatar
    Jun 2013
    IL
    836
    I've had the main drain floor plugs leak. Mine have two ports which only one is used and the other is plugged. If you have a hydrostatic valve in one of the main drains that could be it too. I bought a dye bottle kit for looking for leaks. It was about 15bucks online.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    I've never seen a HS valve in a spa. If he has one in his pool that would not effect the level in his spa.
    -Brian-
    POOL BUILD
