Thread: I guess this is a start up question
    Aug 2011
    Central MA
    38
    Mine is pretty balanced but still green. I've shocked the heck out of it and it's still light green. I'm keeping it running and keeping the filter backwashed every four hours or so. Time will tell I guess. How long does it typically take to clear up?
    27 foot AG, CYA producing in-line Pent-Air Chlorinator.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: I guess this is a start up question
    What are you using to get your numbers? Do you have a recommended test kit?
    Please post a full set of test results. That is the only way we can help you.
    FC
    CC
    PH
    TA
    CYA
    CH
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by Sulteric View Post
    I think the record here is three days - but that guy was obsessed. He set his alarm clock and got up every two hours through the night and spent a full three day weekend brushing and bleaching. Usually a week to ten days with chlorine additions 4 or 5 times a day. It depends also on how much organic debris is in the pool.
    That being said, if the filter keeps clogging and the water hasn't turned grey after a couple days, that indicates the chlorine level isn't staying high enough long enough to get ahead of the algae growth. Have you read the instructions for the Shock Level And Maintain process? Pay attention to the prerequisites.
    If you relate better to pictures, check out some of these threads.
