Results 1 to 8 of 8
Thread: First results on open!
    Cool First results on open!
    Folks,
    Just hauled the cover off and fired up the pumps. With the SWCG off I get.
    FC = 5.5
    CC = 0.5
    TA = 40
    CH = 30
    CYA = 30-35
    PH = 6.8
    Borate = 30 (strip)
    Salt = 1700 (cell diagnostics)
    Can this be right?!?! The pool looks great! Man if this is where I am starting thank goodness I got that mesh cover!
    Looks like I am going to add 180 oz of borax. Should I SLAM anyway?
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: First results on open!
    Don't try to bring the pH up all at once. Make it a couple of steps. At 6.8 you may actually be well below that.
    Bring the CYA up,in a couple of steps also
    I would bring the FC up to about 10 and OCLT to see if anything is growing. Why SLAM if it's not needed
    Support the site
    Great suggestions Tim. Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You need to do something with that swamp of yours.
    And now for some words of wisdom: the best way to really understand something is to try to explain it to someone else. After seven years and opening to that, I think you've got it pretty well down pat. Time to start answering some questions, JD.
    Richard my first year opening like this! And while I'm a 7 year member this is only my 5th year with the pool
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Sounds like an awesome starting point.....
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Lost 0.5 overnight (about 7 hours). Added some chlorine to bring it back up to 13. pH is now holding at 7.5
