Results 1 to 11 of 11
Thread: SOLVED: SWG making pool very bubbly?
    I just opened my pool on Sunday, it was gross and black. I vacuumed a lot out until it got dark outside and couldn't really see what I was doing anymore. I've been scrubbing and back washing since then I did pour a couple gallons of chlorine in (after checking pool math since FC was very low) and enough salt to get up to/little past the recommended salt level.
    I checked the levels Wednesday night and adjusted them right away once I found out FC was only 2 ppm and CYA was 0! I should've checked the pool levels last night but got too tired, I did dump a gallon of 12% chlorine in to hold it over till I had more time to check everything after work today.
    Sorry, I know this doesnt help but the levels are probably about (didn't have time to check before work this morning):
    ph 7.2
    FC 6-10?
    CC 1
    TA ~60
    CYA ~30
    Salt 3400
    So onto my main question, should my SWG be doing this? Or should I not even use it while SLAMing, I was hoping I could use it to bump up/maintain my FC level during the day? I turned it on before I left for work this morning and my girlfriend called me to tell me it looked bubbly. I had her turn off the SWG. This is my 3rd season with the pool, i've never seen it really do that. I've never cleaned the SWG
    Here it is now:
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: SWG making pool very bubbly?
    If you are in a SLAM, turn the SWCG off. You are just forcing it to work when you are also manually chlorinating.
    Support the site
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Your SWCG did that? Almost looks like a type of reaction of a couple of additives or something.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    38,472
    Any chance you used some bleach that was not just plain bleach? If you use some easy pour, thicker bleach it has been known to foam and could be reacting with the SWG.
    If not, sometimes these weird things just happen. I remember one where it looked like a cloud coming out of the jets and would turn the pool white ... just from bubbles due to the SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    That looks like either cheap algaecide or splashless bleach foaming up. The SWG is nothing more than an onsite bleach machine. Same process clorox uses, just on a smaller scale. My gut feeling is to turn the SWG back on and let it finish oxidizing whatever that foamy stuff is. Maybe it'll be done when you get home and can test things again.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    Splashless bleach is what I was trying to remember!
    The only chemicals i've put in there since i've opened it (not at the same time) are 4-5 gallons of HTH 10% chlorine, ~4lbs arm & hammer pool baking soda, 4.5lbs HTH stabilizer, 120lbs All natural salt, and then last night about a gallon of "12%" chlorine I got from the local pool store.
    I forgot that I took a few pics of the pool last night when the SWG was on. I'll check the levels when I get home and run the SWG again. It got a little like this the other day so I don't think it was the chlorine from the pool store.
    Aaron
    This is just a follow up post in case anyone else ever has the same problem. I ended up disconnecting my salt cell and washing it out with water. There were a few pieces of grass on the inlet side that I saw, but I didn't see any build up of anything inside. I then dunked the cell in a bucket of water/muriatic acid as stated in the instructions for my model for a few hours.
    None of the pool stores had the correct "cap" to close off one side of my cell (plus they wanted $30) so i ended up buying a bucket from Lowes for $3. So far so good, the cell is no longer making my pool cloudy and seems to be producing chlorine again.
    Aaron
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: SOLVED: SWG making pool very bubbly?
    I don't see why a little grass would foam up like that. any chance someone put something in the pool, almost like Mr. Bubble or something. Odd.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Quote Originally Posted by DaninFLA View Post
    No one was putting anything in the pool, anytime I turned the SWG on, it would start foaming up like that. It would go away 15 minutes after I turned the SWG off. I think you're supposed to clean the salt cell out with a mixture of Muriatic acid/water every so often. Mine hadn't had it done in at least 5 years. (house say vacant for couple years, this is my 3rd season). No history on what previous owners did, other than selling the pool heater, appliances, and light fixtures on craigslist before they got foreclosed on lol.
    Aaron
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    interesting. guess you just had a ton of calcium build up on the cell and for some reason it was causing that issue. glad its fixed
    Dan
