Thread: Thanks to TFP, no SLAM needed!
    Mar 2015
    Indiana
    79
    Just wanted to say thanks to all the members here that share their wealth of knowledge. If you've been following any of the bioactive threads you know that my first task while attempting my own pool care was to get my CYA from around 500 under control. I got it down to 90, which I know is still considered high, but at least it's manageable for me. So then I knew it would be time to start my first slam. My water looks great, but I went almost three weeks with chlorine <5 and was sure there would be some nasty stuff growing I couldn't see. Based on the pool math results I knew I needed to keep FC around 35. So I started with 12% liquid chlorine and measured FC/CC after each bottle I added. After the third bottle I was at FC of 18 and CC 0. This was around 8:30pm. I decided just for fun I'd try on OCLT at that level. This morning still had 18 FC! I'm sure if I was still using the pool store I would have spent a ton of money and still have a disaster on my hands. So far this year with the exception of water/bioactive costs I've got about $20 in chlorine and $10 in muriatic acid.
    So thanks to everyone again. The posts you make on threads are helpful to more than just the OP. Everyone else searching sees them and unlike most other forums, everyone here giving advise actual says the same thing!
    Next step is to get rid of some slight metal staining and we're ready for the season.
    17x41 Sun Fiberglass Pool 21,500 gallons. Jandy 1hp pump, Hayward Top Mount Sand Filter, Coverstar Auto Cover.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Thanks to TFP, no SLAM needed!
    Excellent!
    You've done really well.
    I'm not so nervous about having low FC for the BioActive reducer run that I'm going to start monday.
    Will start a new thread at that time.
    Dolphin E10 Cleaning Robot.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,202
    Great, glad to hear it!
    Stick around and help answer questions, there is a line of new folks at the door looking for knowledge.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Thanks for the kind words!
    And congrats on your opening
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,023
    Congrats hugenio.
    Divin Dave,
    Mar 2015
    Indiana
    79
    Thanks everyone.
    Borjis - I did not see an issue with algae on any of the bioactive threads so I agree.
