Results 1 to 9 of 9
Thread: Question: swimming while slamming
    Mar 2015
    Houston TX
    45
    Question Question: swimming while slamming
    I am in the process of slamming and my grandchildren want to swim. I am just about finished water is blue but Taking longer than anticipated due to bleeder on filter damaged and can't run on high. The new bleeder is due in today or tomorrow. My question is can they swim with the FC at 10? Thanks
    21x42, 23000K AG ClearwaterII Cartridge Waterway 2HP 2 speed July 2014 TF-100 SWG aquarite with Tcell
    38,260
    Re: Question: swimming while slamming
    Can you see the bottom of the pool? If not, then they should not swim.
    If so, it is safe to swim if your FC is lower than the shock level for you CYA (which you did not report).
    Mar 2015
    Houston TX
    45
    Sorry cya is 80 and FC is 10. Yes I can see the bottom of the pool. Just didn't know if the chlorine would hurt them or bleach their suits?
    38,260
    With a CYA of 80ppm, they could swim with a FC of 30ppm with no issues.
    If you are SLAMing, why is your FC so low anyway?
    Mar 2015
    Houston TX
    45
    Maybe that is why it has taken so long I thought it was suppose be 10???? Please advise!!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Toekneejo View Post
    Chlorine / CYA Chart
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Here is a link to the CYA chart
    http://www.troublefreepool.com/conte...art-slam-shock
    Your shock level is 31-35 so at 10 FC it is taking longer
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mar 2015
    Houston TX
    45
    Oh wow thank you not sure how I had mis read pool school!!!!
    Mar 2015
    Houston TX
    45
    Just FYI I know where I messed up this spring I had drained my pool and hadn't added any salt or CYA so I had slammed adding and using the 20 cya and the target was 10...... Didn't remember the numbers change with the cya!!!! so again thanks
