Results 1 to 8 of 8
Thread: How can I prevent a Spring Swamp?
    meporchmonkey's Avatar
    Jun 2012
    Indianapolis, IN
    8
    I'm obviously doing something wrong. I brought the pool to shock before closing in the fall, but every spring I open the cover to this. It also smelt like a horrible fart. When I got the pump running all the kids ran for their lives. Thankfully no one puked.
    In our climate it's almost impossible to lift the cover back and add chemicals mid-winter. The pool was still a block of ice on top in March.
    I'm still in process of "S." and have not quite gotten to L.A.M. this year. (Baseball, full time job, three kids, hubby broke his arm so he's no help)
    Inground 33,000 gal - Vinyl - Jacuzzi Sand Filter - Pentair 340037 SuperFlo 3/4 hp. Taylor K-2006 Test Kit with SpeedStir.
    38,343
    Re: How can I prevent a Spring Swamp?
    Sounds like you may not be closing late enough and opening early enough. You should close after the water temp is < 60 and open before it gets > 60
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    What was water temp when you closed? What was it when you opened? Close when the water temp is solidly below 60 degrees and open before it gets above 60 is a large part of it. The adage is "Open Early, Close Late." I closed last year when my water was low 50s, mid-October I believe. My pool has been open for the most part for 3 weeks. Water just started coming above 60 degrees, was more like 54 when I started opening. Your spring is earlier and winter later than ours here, most likely, so you should be opening earlier than I do and closing later than I do, weather dependent.
    Isolated Spa - 345 Gallons
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome back!
    Prevention is easy, and the same as the cure...Free Chlorine
    Essential Links:
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    Our pool came with a mesh safety cover. If I didn't close late enough, late Nov/early Dec, and open early enough, late Feb/1st of March, our pool would be green at opening. Ever since I started using a solid cover to block out all light and rain water, and maintain 50ppm borates, I've never opened to a green pool, regardless of water temp.
    Now I close in early Oct and open in early May. Water temp is usually in the mid to high 60s. One season I couldn't open until early June, and despite water temp being in the high 70s, the water was still clear.
    I know each pool/environment is different, but for me the key seemed to be the combination of a solid cover and borates.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jun 2012
    Indianapolis, IN
    8
    Good questions! Um... we closed the pool when the kids started shaking and their lips turned purple from the cold water. I opened last weekend of March there was still ice on the cover.
    Thanks guys! I'll pick up a thermometer this year.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Every year I opened to a swamp despite following the advice here. This year I managed to open and the pool was cloudy but not swampy which is a win for me! I have a mesh safety cover that has seen better days with a few holes here and there. The hole-y cover is probably the reason why I have algae every year since it allows sunlight to hit the water.
    For closing, I waited until my pool temp got to 50 degrees with no chance of warmer weather in the forecast. Closing near 50 degrees instead "under 60" degrees really made a difference for me.
    I added double the max dosage of polyquat 60 algaecide and I really think it made the difference for me. It was overkill on the algaecide, but using the max dosage didn't work for me. I also have the magical bacteria that eats my CYA every winter. My CYA was gone, but I don't have to battle algae.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    May 2013
    Long Island NY
    419
    When I close my pool in the late fall , my cover is always on at least a month before I blow the lines and remove the pump.
    When the cover is on, maintaining FC is easy. When the water is at 50 I shock it and next day lower water, blow out lines and remove pump.
    In the spring, when the water approaches 50, I hook up the pump, run a few hrs. And test the water and adjust. I always have chlorine in the water from the fall. I don't remove the cover until a month or so after I hook up the pump in the spring. I don't need to slam in the spring at all.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
