Results 1 to 18 of 18
Thread: New pool with low TA and CH
    Feb 2015
    Cypress, TX
    54
    I just started up my brand new pool and had turnover this week. The fill water is 9 days old and I have new pebble sheen. I started off with High PH and TA so the startup guy added a gallon of muriatic acid to get my PH down. It was down in the 7.8 range, so I have been adding small amounts of muriatic acid to try and get it down to the lower end range for new pebble sheen. I have my ph down to 7.4 now, but it has dropped my TA down to 51. My main question is when is it safe to start adding baking soda to start raising my TA to the suggested 80-120 range for new pebble sheen? The start up company and pool store seem to think I dont necessarily need to worry about my low TA and CH at this point since it is a new plaster. Pool math says I need to add 7 poounds, 11 OZ of baking soda to get to 80 TA. What frequency and at what time should I start adding? Also, am I okay to not worry about CH at this point? Any other suggestions and input are appreciated.
    CYA -41
    FC - 3.5
    TA - 51
    CH - 153
    PH -7.4
    18k gallon IG gunite/pebblesheen with 3ton moss rock waterfall, 8 ft 12" raised wall & rock accents , 42sq ft 12" raised spa w/ 6 jets & cascading stacked stone waterfall, 3HP Intellifo VS pump,
    420sq ft Pentair cartridge filter, 400,000 BTU Pentair Gas Heater, 1.5HP Whisperflo water feature pump, 1.5HP Silencer Spa Blower, 3 intellibrite lights, EZTouch System 8
    38,235
    Re: New pool with low TA and CH
    What test kit are you using? Those numbers as suspect.
    Feb 2015
    Cypress, TX
    54
    I have ordered the TF-100 kit, and it came in Wednesday. I have not had a chance to use it. I have been using Texsun computerized testing equipment. I have taken my water in daily since startup to have a log. These readings are from yesterday evening.
    I might add that the numbers have been fairly consistent with a steady drop in PH and TA without much other movement in the other readings. The only thing I have done is add 2 cups of MA once or twice a day since Sunday.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Post up some numbers Ricky, get familiar with the kit and trust your results.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Computerized testing is only as good as its design and the frequency of its calibration. Drop based home testing with proper reagents is accurate, convenient and cost effective. Pool store testing is none of those unless they are using the same kit you can, in which case, it's just inconvenient and less accurate for things like FC and pH (arguably the most important daily tests) because of travel time.
    Isolated Spa - 345 Gallons
    Feb 2015
    Cypress, TX
    54
    I fully plan to start testing this evening with my new kit, and I will post up the numbers I get them. Assuming they are similar to the store (bold assumption I know), what is my course of action given my circumstances?
    38,235
    If those are correct, you may not be in too bad of shape, besides the FC getting a little low.
    Feb 2015
    Cypress, TX
    54
    Okay I just used my test kit for the first time. I got a reading of fc between 3 and 5, ph between 7.2 and 7.5 and TA of 70. I went back and looked at my computerized sheet and was at 3.5 fc and TA of 65 yesterday. My 51 was adjusted TA. I have no idea what adjusted TA is but from what I have gathered it's not as important as TA. I think at this point I'm just going to hold off on adding anything except maybe a little baking soda. What do you guys think?
    38,235
    You did not report all the tests ... especially the FAS-DPD chlorine test and the CYA.
    Forget about TA, least important.
    Feb 2015
    Cypress, TX
    54
    Oh I just did the general chlorine. Let me go do the other one.
    Aug 2014
    Northern IL
    4,615
    It's easier for people to read if you post like this: (like you did originally)
    FC
    CC
    pH
    TA
    CH
    CYA
    Feb 2015
    Cypress, TX
    54
    Okay. I finally did it. It took me a couple of tries on some of the tests. The second go around I used the speed stirrer. That thing is legit!
    FC 3.5
    CC 3.5
    PH in between 7.2 and 7.5
    TA I got 70 manually and 60 with speed stir
    CH 200
    CYA 40
    38,235
    Are you sure the CC was 3.5 and not 0? Did you add 7 drops of R-0871 for the FC, then 5 drops of the R-0003 and then 7 more drops of the R-0871?
    Assuming that you meant the CC was 0, you are in pretty good shape. Just keep the FC above 3ppm at all times (based on the CYA of 40ppm) and you should be good.
    Feb 2015
    Cypress, TX
    54
    Yes. I apologize. CC was 0 as. I did not have to add anymore drops. Sorry I am new at this.
    38,235
    No problem. Glad things look pretty good for you
    You should probably bump the FC up to 5-6ppm every day to be sure it does not drop below 3ppm
    Aug 2014
    Northern IL
    4,615
    More than probably, IMHO, until you get used to testing and learn your pool's requirements. Good job!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Maintaining the proper chlorine level for your CYA level is the most important part of assuring that algae doesn't get started in the pool. Here is the Chlorine CYA Chart.
    Good job getting the test kit all figured out. You'll be a pro in no time!
    Feb 2015
    Cypress, TX
    54
    Thanks guys. The test kit is a little overwhelming when you first look at it but has great instructions.
