Results 1 to 9 of 9
Thread: The pool store tests for free ....
    May 2015
    Fayette Ohio
    2
    We take a sample of our water to a pool place and they test it for free. They tell us what it needs and it's always spot on
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: I must be missing something...or I have Wabbaseka's disease
    Quote Originally Posted by kclesbrg View Post
    We do not advocate pool water testing at the pool store here. Our goal is to get people using a recommended test kit and to understand they can do this on their own without buying expensive pool store recommended products.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,521
    How much is that "free" testing costing you in un-needed overpriced chemicals?
    The TFPC method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS and not what someone wants to sell you.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: The pool store tests for free ....
    It's usually worth what they charge you for it.
    Essential Links:
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    exactly how do you know its spot on? If you have a good test kit to test your water then why are you taking in to a store to have tested?
    jtaves85mcss's Avatar
    May 2012
    Cincinnati, OH
    189
    So is advice from the pool store.
    It's when you follow the advice based on their generally questionable testing results that the three card monte starts and your money quickly goes into their pockets.
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Compared to what?
    Welcome to TFP!
    May 2012
    Cincinnati, OH
    189
    kclesbrg,
    Perhaps if you post up a full set of test results from your 3 or 4 most recent pool store tests along with a list of pool store recommendations and what you purchased we can help you determine the whether you are receiving good test results and advice.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Good luck with that approach.
