Thread: Powdered Shock
    May 2014
    Clarksburg, WV
    331
    Powdered Shock
    Is there a way to tell how much a bag of powdered shock will raise the FC and CYA in a pool?
    I'm thinking i could use the bag of shock to raise FC and CYA up and not have to buy stabilizer. Just curious how much it will raise CYA. I'm not really concerned about the FC part. I just dont want to overshoot on the CYA number.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Powdered Shock
    Certainly! Use Pool Math and the section at the bottom of the page that says Effects of adding chemicals​. Make sure you have your pool volume in the table above.
    Isolated Spa - 345 Gallons
    May 2014
    Clarksburg, WV
    331
    Re: Powdered Shock
    I did. But I think I just answered my own question.
    53% Cal Hypo is on the label of the HTH powdered shock I have. Pool math says it wont add any CYA. Just FC and CH and of course salt.
    I thought all tabs/shock had CYA in them? Maybe i've been confused all along.
    TF-100 Test Kit
    How to SLAM
    Feb 2014
    Central Minnesota
    5,080
    Re: Powdered Shock
    Not all shock/tabs have CYA. Depends on the actual chemical formula.
    Trichlor is chlorine and CYA, but less CYA than dichlor per chlorine/FC. Cal-hypo is Calcium Hypochlorite so calcium and FC. Bleach is well... just hypochlorite and sodium.
    Powdered chlorine products:
    Trichlor: FC + CYA, usually tablet form
    Dichlor: FC + CYA, usually powder form
    Cal-Hypo: FC + CH, tabs or powder
    Lithium Hypochlorite: FC + Li, powder
