Thread: Cloudy Water
    May 2015
    mooresville, in
    1
    Cloudy Water
    We have done everything to our pool like we were told from jensons pool and still cloudy. We have changed the sand in the filter. Our numbers r correct and still cloud . Help!!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cloudy Water
    Welcome to TFP from a little way down the road!
    Listening to the pool store is your first mistake. The numbers they claim are correct just won't work. If you could post some test results with your FC and CYA levels particularly, we can help.
    With a sand filter, it can take several days to clear a really dirty pool. Mine has been open since last Friday and I'm just now able to see the main drain.
    If you want to start learning, you can head for
    Pool School.
    Recommended Levels would be a good starting point.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    Re: Cloudy Water
    When you say levels are correct, is that your testing or the pool store?
    We generally find that pool store testing is less than stellar and recommend folk have their own quality test kit. The TF100 at Tftestkits.net is the best value, but there is a list of all the recommended test kits in Pool School (link above).
    Support the site
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cloudy Water
    Welcome to TFP!
    Sounds like you've been through the wringer at the pool store, much like many people before you and myself a few years back. The good thing is that you found TFP and you want to do something different, that will work.
    Getting yourself a good test kit is the first and most important step in taking control of your pool. Here are the TFP recommended test kits: Test Kit Comparison I'd highly recommend the TF-100 from tftestkits.net as it is the best value and has all the reagents you'll need to take control of your pool.
    Contrary to what the pool store has led you to believe, your sand is almost never the real problem. By the time it gets in your filter, it's already millions of years old. 5 years in your filter is nothing for "wear" on the sand. At worst, it may need a deep cleaning.
    I'd recommend getting a test kit ordered, leaving the pool store behind (mixing their advice and ours is BAD) and get yourself acquainted with our methods in Pool School. I know you probably want a quick fix, which is what the pool store is always selling, but seldom delivering. Do yourself a favor and forget the big money quick fix and take over your own pool using TFP. Your wallet will thank you for your patience and finding TFP.
    To help you better, please add the details of your pool to your forum signature. See how here: To change your profile and/or signature, select "Settings" (top right under Pool School button). Scroll down (left side) to "My Settings" & select Edit Profile or Edit Signature.
    Isolated Spa - 345 Gallons
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Cloudy Water
    Hi, Welcome to TFP!
    We need some water test results to diagnose your current issue. My guess is that your CYA/stabilizer level is too high and that your chlorine level is too low as shown on the Chlorine CYA Chart. Chlorine level in your pool needs to be maintained in relationship to your CYA level in your pool.
    Order a TF100 test kit from tftestkits.net
    Read these two introductory water care articles in Pool School
    TFPC for Beginners
    ABC's of Pool Water Chemistry
    Here are the Recommended Levels for your pool
    Here are the Recommended Pool Chemicals to maintain your pool
    Use PoolMath to figure out how much stuff to add.
