Thread: Liner color restoration
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Is there any such thing? I've seen products advertised to help bring back the vibrance of oxidized pool liners. Does this stuff really work, or is it just snake oil? I don't have an example of what I'm talking about. I tried looking it up again online and I don't even know what to search for! LOL
    Mine is four years old now and looks pretty good still. But I can see where I have the ladder mat every year - the liner looks much darker there and better there. I was thinking about trying one of these products but I thought I would seek advice in previous experience and whether or not this is something worth spending my time on. I just remember it being something that you can add to the water and over the course of a few days, it helps to remove the oxidation from the liner.
    I also realize that it could also be from high levels of chlorine because of a misbalance of cyanuric acid. I don't think that's the case here. I've been using the BBB method since I started and I've not had any problems keeping everything in check. I've never had a CYA level above 50. I also don't automatically shock as a cure-all when I have a problem. : ^)
    24' X 54" Sharkline Matrix AGP ~ 15,200 gallon
    1.5 HP Dynamo Dual Speed ran 24/7 at low speed w/250lb. SD60 Pentair Sand Filter
    Plumbed with PVC - buried.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: Liner color restoration
    I'm going to,guess snake oil as I can't wrap my mind around how putting something in the water will restore color to a liner. But, I am just guessing and would defer to someone who has used such a product.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's not the Cya. Liners fade, and very high Chlorine levels (out of range) can add to that. Most fade is from the Sun, as illustrated with your example. There is no product that could restore the color in your pool liner I'm afraid. Once the color is gone, it's gone I do believe.
    Essential Links:
    moze229's Avatar
    Jul 2011
    Central NC
    108
    Thanks for the clarification. The reason I mentioned CYA is that if one's CYA level is high, more chlorine is needed to bring to the proper levels. The result would be a faster fading liner. The sun will destroy anything over a period of time, so this was my original thought. It would be nice though! Thanks.
