Thread: Tile falling off, coping hollow sound!
    May 2015
    Quakertown Pa
    2
    Hi Everyone!
    We just opened our inground concrete pool, and noticed about 25 tiles fell off. Also noticed cracks in the tile around the skimmers and a few on the other side of the pool. We live in the cold northeast, and it was a brutal winter. Also, the pool company we used stopped pumping water out of the pool when closing it, said they didn't do that anymore, never had any problems. Should have been a red flag, I know. Anyway our pool is 11 yrs old now. Never had a problem. Have had two pool guys come out. They also say the brick coping has a hollow sound when tapped along the side of the pool. Anyway, they recommend replacing the tile and coping.5500 price tag, which seems high. Any thoughts? Why does the coping have a hollow sound, where did the mortar go? Is it from water freezing or bad install? Is it reasonable to just repair the missing tile, lower the water from now on at closing, and buy time until I have to replaster and just do it all at once? Help!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Tile falling off, coping hollow sound!
    The hollow sound is not a valid test. Mortar does not disappear. There is usually not 100% fill under a stone when setting it. Depending on where you knock on our coping it can sound hollow here and there. The question is whether it is stuck or loose.
    Yes, it is fine to clean up the tiles that fell off and put them back on the wall and regrout. Same for the coping.
    11 years of no problem is evidence of a very good install. It is definitely a freeze/thaw movement issue. We even had a little of that on our pool in TX with the crazy cold winter.
    And welcome to TFP!
    Mar 2015
    Pearland, Texas
    11
    It might be worth doing a quick bucket test to see if you have any leakage.
    Partially operational.
    17,000 g, SWG, tanning shelf, bubbler, slide grotto, Prism Matrix - Deep Blue Sea, 2x Hayward Ecostar VSP (one filter, swg, and bubbler; one slide and grotto).
    May 2015
    Quakertown Pa
    2
    I appreciate all of the input and information received!
