Thread: Use sand instead of concrete for in-pool table base?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I just bought this table for the shallow end of my pool:
    http://www.aughog.com/product-catego...n-pool-lounge/
    I'm not using an umbrella with it (its just for drinks...water dodgeball continues to harm many fine craft beer poolside )
    You're supposed to fill the base with concrete, then water...but I'm thinking about picking up a 50 lb bag of sand instead after work tonight.
    Do you think that would work well enough for it to stay put since im not adding an umbrella?
    I looked up density and sand vs cured concrete seems to have about a 50% differential....
    I realize I may just have to try it to find out but though I'd ask in case someone has used this
    Thanks in advance if you have tips!
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: Use sand instead of concrete for in-pool table base?
    Mine would be a guess, but I agree without the umbrella being pushed around by the wind sand would proably do it.
    I like the idea, gotta look,around for one. Just, no glass in the pool
    Support the site
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    Thanks, Tim. You're correct...leveling sand worked fine and was nice and heavy. No glass in my pool either...I have plastic beer glasses folks have to use...which get knocked over all the time on the deck edge the holes in ths one are big enough to take a big plastic beer glass!
    Helpful Links:
