Thread: filter covering question
    Jul 2008
    Bucyrus, Ohio
    I am curious to know when to cover my sand filter. I closed my pool down 1 week ago and was told to open the drain and top of sand filter to allow it to drain. I did that and now I am wondering when is it ok to cover it? If I tip the filter to the side alittle bit of water drains but the sand seems really dry, I have put my hand all the way thru it.
    Is it safe to cover and not fear freezing and cracking of the filter?
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    Re: filter covering question
    A week should be plenty of time to drain. As long as you close it up/cover it so no water can get in the filter will be fine through the winter.
