Thread: 1st test of the season
    Aug 2014
    East Northport, NY
    155
    In the process of SLAM and here are my numbers, thoughts?
    FC - 5
    TA - 90
    CYA - 35
    Calcium - 125
    Thanks
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: 1st test of the season
    I replied to your other thread. Everything looks fine other than your FC. It is way too low.if you are in a SLAMyour shock level for a CYA of 35 is 12-16. I would shoot for 16. You have to keep it there as much as possible. I tested every 2 hours when I started my SLAM. There is a link in my signature if you want to look through it.
    What is your CC
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Aug 2014
    East Northport, NY
    155
    I suppose I am adding more bleach tomorrow, thanks
    TF-100 Test Kit
    Aquabot Bravo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Ok. You want to keep at 16 as much as possible. The more it falls below shock level the longer it will take. We also need to know your CC reading. After you check FC you add 5 drops of R003 then mix. It will turn pink if there is CC. You add R0871 and count the drops until it turns clear then multiply drops by .5 to get your CC reading. If it does not turn pink when you add the R003 then your CC is 0
    Lisa
    Casey's Avatar
    SW PA
    10,448
    If you're SLAMing the pool, SLAM it. The longer you wait to add chlorine the longer it will take to clear the pool. You also give algae another chance at reproducing and wasting chlorine.
