Today I received the following list of equipment and model numbers for equipment renovation for a 33K gallon pool. How might you rate these items? Are the following first-rate? Would you substitute a different brand, model, if you meant to install the best?
Equipment to be installed.
1. JDY 2 hp Medium HP FLOPRO Pump
2. PB4-60 Polaris Booster Pump .75HP
3. JDY Clean & Clear Filter Cartridge 580 SQFT
4. T30404R Subpanel W/2 T104 Timers 100 amp
5. 4716 Neverlube CPVC Valve 2 Port 2-2.5"
6. Tropicool by Aquacal TC-1000 ACDSENA Water Chiller
7. Saltwater Sanitation System
a. JDY 301704 P4 Computer
b. JDY 301412 Sub Panel
c. JDY 451405 Salt Cell
8. 200 lf 100 amp #1 awg copper wire feeder
9. 200 lf 2 diameter PCV underground pipe with pull box
10. 2-GFCI 20 amp breakers
Thanks for your opinions !!!
