Results 1 to 9 of 9
Thread: Bleach Usage
    Mar 2013
    CT
    351
    Bleach Usage
    i opened my pool a few weeks early this year because i want it to be ready for Memorial Day. Its been open for about ten days or so. The past week i noticed that I've only needed to add about 48 oz of bleach per day - based on my Taylor test kit. That's a good deal less than I was adding most of last Summer.
    Do I not need as much on an every day basis because the water is so cold - 60 degrees - and no one is swimming yet?? It doesn't seem like the FC goes down much at all within 24 hours. It goes from 6 ppm to about 5 ppm in 24 hours...does that seem right for my circumstances??
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Re: Bleach Usage
    It's still,a little early in the season so you may not be loosing a lot to the sun.
    What is your CYA?
    Support the site
    Mar 2013
    CT
    351
    Re: Bleach Usage
    CYA is about 20, Just added some granular conditioner in a sock - about a pound - yesterday. Im paranoid about adding too much so I figure i would add a bit - test in a week - then go from there...
    Mar 2013
    CT
    351
    Re: Bleach Usage
    Anyone?
    Orlando, FL
    690
    Re: Bleach Usage
    My pool is not using a lot of chlorine either. I attribute it to the fact that I finally have the chemistry right and because there have been a lot of cloudy, rainy, overcast days, which help the chlorine stick around. The kids have been swimming but together they equal a small adult. I also know the days have not been super hot because my solar has been struggling to get past 82 for more than a week. Last month the pool hit 86.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2014
    Franklin, NC
    9,196
    Re: Bleach Usage
    Quote Originally Posted by dschribs View Post
    that is a good way to,add CYA. Take it up in small slow steps.
    Support the site
    Aug 2014
    Northern IL
    4,615
    Re: Bleach Usage
    And CC is okay?
    Ellington, CT
    262
    Re: Bleach Usage
    With the cold water and low usage, I believe that the chlorine demand will be less.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Bleach Usage
    Generally that's true yes. Lower temps let FC hold longer.
    Essential Links:
