Results 1 to 10 of 10
Thread: My first readings...
    May 2015
    Avon, IN
    23
    Just tested for the first time. Now what?!?
    Using the Taylor K-2006
    FC 11
    CC 3
    Ph 7.0 (probably less but doesn't go down any further than that)
    TA 220
    CH didn't test
    CYA 40
    Get the ph down with borax and then SLAM due to CC??
    Opinions/help appreciated...
    Water is clear but not sparkling clear.
    18,000 gal; inground; vinyl; 18' x 36'; Cristal-Flo Sand Filter (new sand 4/27/15); Taylor K-2006 test kit; Avon, Indiana
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: My first readings...
    Yes, pH needs to come up first with Borax. As you really can't tell how low it is, careful you don't add too much at once and go high.
    Was it just opened, just installed or,other - what is the history
    Support the site
    38,295
    I think you are correct to SLAM due to the high CC value.
    I would be inclined to leave the pH and start the SLAM. Your high TA is going to raise the pH fairly quickly. Although it is safer if you raise it to around 7.2.
    May 2015
    Avon, IN
    23
    Been opened since April 1...been using this method for about 2 days!!! Before that was pool stored and spent waaaaaaay too much money on chemicals. I have borax and then also can just start SLAM tonight too.... What's the best thing to do? This is a new house with a pool for us. Pool been here a few years though.
    May 2014
    Franklin, NC
    9,184
    Go ahead and bring the pH up to 7.2 and SLAM. I'm going to,guess this will be a quick SLAM.
    Support the site
    May 2015
    Avon, IN
    23
    Hoping so.... I'm pretty excited my numbers are as good as they are!!!!
    May 2014
    Franklin, NC
    9,184
    The key is - what is the water temperature. Will you swim at that temperature?
    I'm a wimp, 75 is my cut off.
    Support the site
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Quote Originally Posted by tim5055 View Post
    In I am the wimp. I won't get int the pool unless it is 85 degrees or higher...lol
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    May 2015
    Avon, IN
    23
    Kids were in it tonight. My feet were in it but that's it. Temp is 78. No heater. Not too shabby for indiana in May!
    May 2014
    Franklin, NC
    9,184
    Ours is about 78 now. 70 to 75 I jump,in and get out & head to the hot tub. Above 75 I can stay in for a few minutes. Much prefer 80+
    Support the site
