Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Chlorine Consumption Rate
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    It seems to me I'm using more chlorine than I should, so I started tracking how my Fc changes over time. I started with trying to keep 3 PPM chlorine with 30 PPM CYA, but have since moved to 5 PPM chlorine at 40 CYA. The data is a bit immature at this time, but it seems like I'm adding more chlorine now that I'm at 40 CYA than when I was at 30 CYA.
    Is this consumption realistic, or should I consider increasing the CYA? The pool sits in full sun all day & water temperature has been in the mid 70's. Consumption rates are shown in PPM / Hr.
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Chlorine Consumption Rate
    You get a lot of intense sun. Expect 3-4 a day loss. You can try moving up your cya to 50 and see how that does. Still, 2-4 at that range is not unusual at all.
    Essential Links:
    38,303
    At higher CYA levels you should lose less FC ppms to the sun, even though the FC level is higher.
    Apr 2015
    Round Rock, TX
    25
    I'm also in TX, and I burn off approx 4-5 ppm per day at CYA of 50.
    Just goes with the territory I think.
    12,350 gallon IG plaster pool
    Hayward cartridge Swimclear 4025 filter
    Hayward Super II 2.5 Hp pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's very common. Our Mod WoodyP reports 4-5/day at 50-60 Cya every summer if I'm not mistaken.
    I have a good deal of shade and I'm always less. Maybe 2-3 with no load on the pool.
    Essential Links:
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    well its hard to do that analysis until your pool temperature and outdoor temps are stabilized. increases in pool temp along with the increasing intensity of the sun are going to mean your FC consumption rate is going to be increasing no matter what the CYA level is. interesting analysis, but I think there are just too many uncontrollable variables for it to be of use right now. maybe in another month when things are more constant with sun/temps
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Going on 6th year here now and losing about 4ppm daily with CYA at 50 or 60. No change in consumption rate when I added borates last summer as an experiment either. Pool full sun all day. It is what it is I guess!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yea, and the load on everyone's pool varies as well, and that factors in.
    Essential Links:
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    In NH, pool being in sun pretty much all day, I use about 2ppm FC per day...
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Saturn94's Avatar
    Mar 2015
    Virginia
    500
    About 4ppm FC daily loss here in SE VA. Full sun most of the day, CYA 70-80.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Quote Originally Posted by Saturn94 View Post
    I'm in Chesapeake. Last Summer I took my CYA to around 50 and my FC loss averaged 3.5 PPM. My pool has no shade. My CYA almost vanished over the Winter, probably because I stopped adding Chlorine when the water temp dropped below 50. I'm not complaining though...I've been slowly adding CYA using pucks. I like not having to use Bleach almost every day...makes me feel lazy. I plan to take my CYA higher this year (70?) to see if my FC loss drops compared to last Summer.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    My pool only gets full sun about 4 or 5 hours per day. The rest of the time it varies from 25 - 50% shade. The chlorine consumption is pretty constant at 2 ppm/day with a CYA of 40. I've tried raising the CYA from about 30 to 60 ppm and the chlorine use does not seem to change enough to measure any difference.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    In Savannah during the summer my pool uses about 4 to 5 ppm a day. The solar cover helps slow it down, but raises the temp too much in the summer.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Sep 2014
    Cibolo, TX
    89
    Awesome discussion! Thanks for the reassurance.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Question about this. Assuming CYA of 40-50 still gives a loss of 4-5 FC / day. What is the advantage to keeping the CYA at that level?
    If you put bleach in the pool in the morning and go to work. When you get home at night you might have zero to very little FC still in the pool. And now you have to bring it back up to 4-5 for the recommended levels.
    But if you have much less CYA in the pool, say 0-20. You put the CL in the pool early. And when you get home, you will also have 0 FC. But at least the minimal / recommended FC is much lower.
    It just seems like with those high FC loses, keeping CYA very low is cheaper over the long run.
    I know Im missing the point. But can someone explain?
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    38,303
    Quote Originally Posted by mitch08 View Post
    The higher the CYA, the higher the % of the FC that will be protected.
    If you have 0 CYA, all your FC will be gone in a few hours.
    If you have 30ppm CYA, you may lose 2/3 of the FC in 24 hours, targeting 6ppm you would be down to 2ppm (the minimum for your CYA) ... loss of 4ppm
    If you have 50ppm CYA, you may lose less than 1/2 of the FC in 24 hours, targeting 7.5ppm you would be down to 4ppm ... loss of 3.5ppm
    NOTE: numbers are a generalization and exaggerations to show the concept.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    That is why I believe a constant addition of a small amount of chlorine is better than slugging the pool once a day or adding it over a short period of time. When you add chlorine once per day you have to add enough to be sure you still have some FC available when you add it the next time. When using the liqudator or Stenner feed pump a small amount is added whenever the main pump runs and the FC stays mostly constant all day. It just seems intuitive to me that maintaining a constant FC is better than slugging it with a large dose one time then letting the concentration drift down.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Got it. Makes complete sense. Thanks a lot for the explanation!
    Mar 2007
    San Rafael, CA USA
    12,082
    See this post for an example table of how higher CYA levels even with proportionally higher FC levels ends up have a lower absolute chlorine loss rate. There is an apparent CYA shielding effect above the effect of protecting chlorine by having it bind to it.
  20. Back To Top    #20
    YoRgH's Avatar
    Jun 2014
    Roberval, Québec
    40
    I am asking,
    For the correct CYA suggest for a pool, should we have a chart with the maximum hours direct sun exposure by day?
    For now, we suggest the same CYA for a pool receiving 6 hours direct sun and another receiving 12 hours direct sun....
    Sorry for my english, je suis francophone
    I live in north, no ice in my pool since may 1 !
    Stylus aboveground swimming pool 45 000 liters
    18' round and 52" high with sand filter
