Results 1 to 8 of 8
Thread: Pump and Filter Noises. Normal??
    May 2015
    River Falls, WI
    124
    Hello all!
    First post. First time pool owner. Learning lots.
    Iíve only had the pool open less than a week. I opened it myself. I just received my Taylor test kit and picked up my initial supplies to jump on the BBB bandwagon. My first test and chemical dump was today and it seems as though Iím on my way to a TFP.
    My question is about the noises that come from the pump/sand filter. As of today, actually after my chemical dump my filter seems to have taken on more of a sloshing and gurgling series of noises and the pump has noticeable water activity going through it. Prior to this, the pump area barely looked like water was racing through it even though it was, and I donít think there were noises like this coming from the filter.
    Hereís a short video:
    https://www.youtube.com/watch?v=F-Yac0xaxcE
    Thanks for any help as I continue learning.
    38,275
    Re: Pump and Filter Noises. Normal??
    Welcome to TFP!!!
    What chemicals did you add and how did you add them?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Welcome
    What the heck is inside the pump strainer basket?
    I hope you didn't confuse skimmer basket with strainer basket when you added the CYA.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Yea, it looks like a couple of old paper towels spinning in the strainer basket. On the sand filter is there apurge valve of some sort to get the air out. Sounds like the filter is filled,with mostly air and the water being pumped in is just sloshing around.
    Support the site
    May 2015
    River Falls, WI
    124
    My numbers were:
    FC 5
    PH 7
    TA 70
    CYA 70
    My pool is approximately 22,000 gallons so I used the calculator to get the amounts. So I added just shy of a gallon of bleach, something like 40 ounces of baking soda and an entire box of borax. It called for more borax but I decided to pull back on dumping the full amount. I'll add more tomorrow if needed.
    I added the bleach straight into the pool. I added both the baking soda and borax directly in the skimmer slowly.
    Since my original post I decided to do a backwash and rinse. To my surprise, even though I just backwashed a day or so ago there was a lot of junk in the site glass. Additionally, there is no more gurgling, and the pumps strainer glass is perfect again. No more swirls and air bubbles. So I guess it was just in need of a backwash/rinse.
    38,275
    You should backwash when the pressure rises 20-25% over the clean pressure.
    May 2015
    River Falls, WI
    124
    There's no gauge anywhere on my system. I guess I'll need to get one.
    38,275
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
