Results 1 to 9 of 9
Thread: Concrete is Stained, need help
    Jul 2013
    Garnet Valley, PA
    3
    After our pool cover was removed to open our pool, there is a huge light orange stain all the way around the entire pool underneath where the cover was placed. Power washing with water did not remove it and it looks like a chemical stain of some sort. Need help to identify what the heck this stuff is and how to remove it. Appreciate any help!
    32K gal, IG, Plaster, Jandy DEV60 DE 150 flow rate, 2hp VS FloPro, Jandy LXi heater, AquaPure SWG, Spa w/ spillover
    38,251
    Re: Concrete is Stained, need help
    Welcome to TFP!!!
    So that just appeared suddenly over the winter?
    I have no idea what it is, but I agree it looks chemical and to me does not appear like it is going to be possible to remove it.
    Jul 2013
    Garnet Valley, PA
    3
    We had someone professionally close and open it, obviously the pool deck wasn't like that prior to closure. Now the entire deck area is stained like this under where the pool cover would have been. It's a total mess
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,316
    sounds like the closer/opener has some explaining to do.
    Dolphin E10 Cleaning Robot.
    Feb 2014
    Upstate, NY
    390
    Just a thought here. How about trying some bleach in a little area ?
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    4knights's Avatar
    NE Kansas
    419
    Have you had any episodes of acid rain this winter?
    Ron- Kansas. IG fiberglass, Riviera 30 Freeform 13600 gallons,
    EasyTouch 4 w/IC20 SWCG, Pentair Whisperflo 1hp, 2 speed 220 pump, Hayward ProGrid 4820 DE filter using Eco Klean instead of DE, 2 Savi Melody 12v 5 color LEDs, Raypack 266k btu millivolt heater, Arctic Armour Mesh custom safety cover (Total self Install) TF-100 test kit w/Magic stir.
    Jul 2013
    Garnet Valley, PA
    3
    We tried a diluted bleach water solution on a small inconspicuous spot with no results whatsoever. The pool company stated we don't have a warranty for the deck so we're trying to figure out on our own what the stain is and how to remove it. It's even on our stonework, turned it orange.
    No episodes of acid rain this winter either
    4knights's Avatar
    NE Kansas
    419
    wonder if it was muratic acid condensate for not mixing well before closing? Sorry just guessing. I would also check on the concrete network- one of the members their may have an idea as well.
    I have the same problem. Any answers?
    http://www.troublefreepool.com/threa...rete-Yellowing
