Results 1 to 13 of 13
Thread: Help Locating Part for Old Pump
    Mar 2015
    Upland, CA
    222
    Just purchased a new home that came with an in-ground ~20,000 gallon plaster pool that is very old, but functional. Luckily when my TF-100 arrived the water tested good (CYA 40, CH 325, TA 90, FC 5). However, the Aqua-Flo A pump has a trap cover on it with a broken lock handle and it's not see through. I'm hoping someone can help me identify a see-through lid that will fit in place of this one. It's also leaking slowly at the outlet and I can't see how to stop it without a lot of replumbing.
    PUMP
    COVER
    38,305
    Re: Help Locating Part for Old Pump
    What part is broken?
    A quick search and I see the lids and twist handles are still available.
    I kind of doubt there is a clear lid that would mat up exactly. The Hayward RS pump has a similar type of lid.
    Mar 2015
    Upland, CA
    222
    The lock handle is broken and a piece of the bolt is still stuck in the basket body. I was hoping to find a clear lid so I don't have to pop the cover open to see if there are any leaves and such.
    38,305
    If the bolt is stuck in the pump body, how would you attach a different lid
    I think you might need to start considering replacing the pump ... that one has had a LONG life
    Mar 2015
    Upland, CA
    222
    By drilling out the bolt.
    I'm investigating options for replacing the filter and pump, as well as replastering and tiling the pool.
    38,305
    Well, if you got the bolt out, you can buy a replacement for it ... still would not give you a clear lid. There are a few clear lids that attach by bolts on the side, but I have no idea if the bolts would align and if it would seal on the pump basket.
    Based on the limited information you have provided, You should only need a smaller 1HP pump, ideally a 2-speed ... or in CA, consider one of the smaller VS pumps.
    Mar 2015
    Upland, CA
    222
    Thanks. I was wondering about pump sizing. The pool only has one skimmer box and a spa attached by overflow to the pool. I'm hoping that the plumbing is OK, but I am getting bubbles in the return. Hopefully that's just an issue with the basket seal (but I worry because only some of the returns have bubbles). If I can save some money on a smaller pump I can put that into a larger filter. I'm going to go with a cartridge to minimize water use.
    laveenmoose's Avatar
    May 2012
    Laveen (Phoenix), AZ
    41
    Try Perry's Pool Pump - http://www.perryspoolpump.com/ - they rebuild/repair pool pumps for most of the pool guys here in Phoenix, as well as out of State people. I bought a replacement pump, and it is quieter than my original Haywood Stealth. Here's their number - 602-943-8850.
    Good luck.
    10.5K IG gunnite pool with micro-pebble finish in Caribbean blue with Baja step. Haywood main filter with Perry's Pool Pump 1hp motor. Jandy CL-340 cartridge filter. Circupool RJ30 SWG system. TF100 test kit with Speedstir. Floating beer cooler.
    38,305
    Oh, you have a spa? That would likely require a larger pump than I mentioned above. This is why you should fill out your signature. Please add your pool details to your signature as described HERE as it will help us help you.
    Mar 2015
    Upland, CA
    222
    How's this?
    EDIT - It's not posting my signature.
    One more try.
    Ah ha! No sig with quick post.
    38,305
    You need to check the box below the quick reply to show your signature.
    Mar 2015
    Upland, CA
    222
    It is checked on both posts. I think the issue was that the page wasn't refreshed after updating my signature.
    20k gal. IG plaster w/spa. 2 HP Aqua-Flo "A" pump, Hayward DE6020 filter. "The Pool Cleaner".
    38,305
    There it is.
    So anyway, you will likely want to stick with a 2HP 2-speed pump or one of the larger VS pumps to ensure adequate flow for the spa.
    You filter is a good bit smaller than I would recommend for that size pool and your location. For DE, I would go with 60sqft, but you mentioned a cartridge, so for that I would look at a minimum of 300 sqft.
