Thread: Can you add a light to a liner pool?
    May 2015
    Suffolk, VA
    4
    Hi all this is my first post! I just found this sight and now know how to SLAM my pool this spring. Anyway one thing we don't like about our pool is that is does not have a light. Is there any way to add an effective light to the deep end? There is not a niche. It is a 20x40 liner pool probably built in the 70's. Good shape but no light. Not real excited about a floating light either. How would I do this? Thanks!
    Rick
    22,553
    Re: Can you add a light to a liner pool?
    While you can add one it's a lot of expense to retrofit a niche for a light.
    If you have a concrete deck you'll have to tear a piece of the deck up and dig down to the level you need to install the light and you'll also have to drain the pool and most likely have to replace the liner if it has any age on it. Then depending on whether the walls are wood or concrete, you'll have a little to a lot of work to do getting through the wall.
    If you could find a true niche-less light it would be easier, but then you'd have the cord running up the wall and across the deck, so it wouldn't look very good. You'd also have holes through the liner that you'd have to make sure were sealed well.
    Here's a wall mounted light, but as I said the cord is a problem.
    May 2015
    Suffolk, VA
    4
    Quote Originally Posted by Bama Rambler View Post
    Yea thanks that is what I was afraid of. I have some lights I put on my boat I wonder if they would work? Still have the same problem with the cord but might be easier to hide the cord.
    22,553
    Just be aware of the rating. For true underwater use they need to be rated IP68.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I bought a couple of these last year. They are not the brightest, but they help some. They just screw into the returns, and the water returning to the pool turns propellers that generate enough electricity to power the leds. I have to run the pump on high for the lights to be worthwhile.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    May 2015
    Suffolk, VA
    4
    Quote Originally Posted by sargent View Post
    You know I saw those and read the reviews on Amazon. Some people liked them and some not so much. Have you had any problem with them? Thanks
