Thread: DR,LF,HH and HL codes very frustrating
    May 2015
    Toms River NJ
    4
    Hello,
    I have a Spa with a VS 501Z Balboa spa pak. I fill up the water and then turn on the spa from breaker. It goes thru the primer mode then kicks on the low speed motor pump. It runs for about 15 minutes and then comes up with the Low Flow or Dry etc. This Spa pak is 8 months old and all worked prior to shutting down for the season. I thought it might be air lock but when I turn blower motor on and the 2nd speed of the jet motor jets blow lke crazy. Disconnected all connections and checked for some obstruction but cant find any. I als checked the 2 pumps to see if there is anything stuck in there. The impellers spin freely. Any ides would be greatly appreciated.
    Thanks
    Glenn
    I have a Spa with a VS501Z Balboa spa pak. Also this spa pak is 8 months old.
    Knoxville, TN
    41
    Re: DR,LF,HH and HL codes very frustrating
    Sounds like the programming is configured for a circulation pump. Verify the dip switches are in the correct positions for the equipment you have.
    May 2015
    Toms River NJ
    4
    Quote Originally Posted by CPSScott View Post
    Scott the tub worked fine before I closed it up for the winter. Now it is having these issues.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Try your pressure switch. Its a cheap part and usually remedies "low flo" messages if nothing else seems amiss
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    May 2015
    Toms River NJ
    4
    Thanks For your help. It wound up being the 2 speed pump. Had a guy come over and look at it from Auqa pro spas. He basically did everything I did and was frustrated also. He changed out the temp sensors in heater to make sure that was not it. I told him i thought it might be that pump. He went to his van and got one and installed it and that was the problem. Pump was heating up and then shutting off after a while. Expensive though $550 seems kind of high. Charged $445 for the motor. The motor was 3" Waterway PF-30-2N22M. I looked the motor up online and it looks to be around $285. I called him and said that and he said the motor is around $415. Does anybody know what the price of that motor is?
    Thanks
    Again
    Glenn
