Just purchased our second home about a month ago and a beautiful IG SWG vinyl pool came with it. Opened it this week and have been studying TFPC everyday. So far chems look solid just working through a few minor issues (below). Threads here have been super helpful so thought I'd dive in (pardon the pnu) and join you nuts.
* Slight air leak on pump inlet fitting - rewrapped with tape and air suction disappeared but thought I heard it again about an hour later... will keep an ear out for it... possible that someone cross threaded the fitting once and it's causing issues getting a good seal.
* Slight water leak from compression fitting on pump outlet. Replaced o-ring and added super lube... leak is now at 1 drip per 2-3 sec... might need to replace the compression fitting
* Heat pump is 2 years old, according to prior owners, but I'm getting a LP (low pressure) error code. Seems it could be due to the main fan... will open 'er up later and test the fan to see if that's the issue... otherwise will need a tech to check the coolant.
All minor issues IMHO... looking forward to jumping in once the temp comes up.
Now... off to research opinions on cleaning bots and swallow that pill...
