Results 1 to 9 of 9
Thread: Pool noob - TFPC fan
    rgbysgt's Avatar
    May 2015
    Lakeville, MA
    3
    Cool Pool noob - TFPC fan
    Just purchased our second home about a month ago and a beautiful IG SWG vinyl pool came with it. Opened it this week and have been studying TFPC everyday. So far chems look solid just working through a few minor issues (below). Threads here have been super helpful so thought I'd dive in (pardon the pnu) and join you nuts.
    * Slight air leak on pump inlet fitting - rewrapped with tape and air suction disappeared but thought I heard it again about an hour later... will keep an ear out for it... possible that someone cross threaded the fitting once and it's causing issues getting a good seal.
    * Slight water leak from compression fitting on pump outlet. Replaced o-ring and added super lube... leak is now at 1 drip per 2-3 sec... might need to replace the compression fitting
    * Heat pump is 2 years old, according to prior owners, but I'm getting a LP (low pressure) error code. Seems it could be due to the main fan... will open 'er up later and test the fan to see if that's the issue... otherwise will need a tech to check the coolant.
    All minor issues IMHO... looking forward to jumping in once the temp comes up.
    Now... off to research opinions on cleaning bots and swallow that pill...
    IG 18x36 Vinyl - SWG
    Hayward: Aqua Plus, Filter DE4820, 1.5hp Pump, Heat Pump HP21104T
    38,279
    Re: Pool noob - TFPC fan
    Welcome to TFP!!!
    So, what test kit are you using to maintain your pool?
    rgbysgt's Avatar
    May 2015
    Lakeville, MA
    3
    Welcome to TFP!!!
    Ordered the taylor k-2006 but waiting on delivery... until then I've been using regular old test strips and the local pool supply store about 1mi down the road.
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Welcome aboard. Give us your numbers when you get the kit. Sounds like you're going to be fine.
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP! Nice first post!
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Quote Originally Posted by rgbysgt View Post
    I had a bunch of leaks and used some Permitex #2. Leaked were gone. Teflon tape can cause damage. I broke my skimmer by tightening too tight with teflon tape. 175$ mistake. Now I go finger tight with Permitex then no more than two turns. Sealed does not always mean really tight.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    rgbysgt's Avatar
    May 2015
    Lakeville, MA
    3
    Quote Originally Posted by yostmatt View Post
    Great advice! thanks! I'll add Permitex to my shopping list. Always careful to never over tighten... in my experience, engineers always double tolerances for pressure ratings so if it isn't sealed after it's been screwed on 75%, it probably won't be sealed if you screw it all the way down (under most circumstances - some types of fittings need the full threading for reasons other than pressure).
    Casey's Avatar
    SW PA
    10,438
    Welcome to TFP
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum! Another plug for posting your test numbers once you get your K-2006.
