Results 1 to 13 of 13
Thread: Hard Plumbing my AGP - Need Some Confirmation Please..
    Jun 2014
    Youngstown, OH
    179
    I've decided to hard plumb my pool.. Just thinking it out before I do it.. I saw the big thread here and took a lot from it but his setup is different then mine..
    Firs thing I'm thinking I need to replace all the fittings shown in the pictures here with 1.5" male adapter shown below..
    Once all those are replaced I am going to put a ball valve and a union right under the skimmer and then PVC to the front of my pump.. From the other port of my pump is going to be PVC to the sand filter.. From the sand filter is going to be PVC over to the return with a ball valve and union placed right at the return..
    Does that all sound correct? Should there be any stop valves placed anywhere else while I am doing this?
    Also, I am going to be adding a heater this year.. What should I do, if anything, in preparation for that being I am hard plumbing?
    Thanks
    Installed in 2014 - 24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed //
    Installed in 2015 - Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    Mod Squad pooldv's Avatar
    DFW, TX
    24,496
    Re: Hard Plumbing my AGP - Need Some Confirmation Please..
    That will cover it on valves. Ball valves aren't the best choice, they seize up and break. Jandy neverlube or equivalent are much better and not much more expensive. Pentair and others also make them.
    Jun 2014
    Youngstown, OH
    179
    These seize up and break??
    DFW, TX
    24,496
    I've never seen them with black handles, usually red or blue handles. Yes, lots of unhappy people with those ball valves.
    Need this
    http://www.sunplay.com/jandy-never-l...ort-valve-4724
    or this
    http://www.sunplay.com/jandy-never-l...ort-valve-4716
    One season on my old AG pool and my handles broke, had to use channel locks on it. When pool was gone I happily smashed the ball valves with a hammer. Never again. New IG only has Jandy valves. Worth the small (overall) price cost.
    Using Tapatalk
    Jun 2014
    Youngstown, OH
    179
    Wow! Really??? That sucks to hear.. Those Jandy's are expensive as ****.. $90 for two!
    If I did go that route, or regardless, actually... How many shutoff valves should one have in their setups? Just (2)? One off the skimmer and one off the return?
    I have a pump, sand filter, and gas heater..
    Thanks
    Apr 2013
    Eatonton Georgia
    145
    I'm in the process of hard plumbing my pool. It's a conventional metal wall pool and my filter and SWG are Intex. Besides me making up some adapters for Intex, our situations sound similar. On the line from my skimmer I used a ball valve like you have pictured above but I chose one with threads and used the adapters you have pictured in your first post to go to glued PVC from there. The reason for this is twofold. First of all if the valve does freeze up or break in some way, I can get it out without cutting pipe apart and secondly, it's too easy to get glue into the slip joint type ball valves and gum them up when you are installing them. The only thing I haven't put in that you are considering is unions. That's because, between the threaded fittings into the ball valve and the nuts on the Intex connections, I have several points where I can unscrew things. BTW a union is really not that hard to add if you miss putting one in in a critical spot and then later decide you need it.
    18ft. diameter, 48 inch deep Sharkline Reprieve AGP, 7000 gallons, Intex 14 inch sand filter with 3/4 H.P. 2,150 GPH pump, Intex SWG
    TF-100 test kit
    DFW, TX
    24,496
    Quote Originally Posted by tbird2340 View Post
    Yes, that will work fine.
    DFW, TX
    24,496
    Jun 2014
    Youngstown, OH
    179
    Quote Originally Posted by pooldv View Post
    Thanks PoolDV.. Those look much easier on the wallet..
    Why do they say "1.5" X 2"" ? All the plumbing is going to be 1.5" so not sure what the 2" means..
    OK so I just need 2, that's good.. What about unions? Where would you place the unions so you can remove everything easily for storage?
    Thanks again.
    DFW, TX
    24,496
    You're welcome. 1.5" inside diameter and 2" outside diameter. I think I'd put the unions right after the valves.
    Jun 2014
    Youngstown, OH
    179
    I bring the pump in for the winter.. I'm guessing I would need some unions by the inlet and outlet of the pump as well, right?
    DFW, TX
    24,496
    Sure, putting them on each end of the hoses will make it easier.
