Results 1 to 12 of 12
Thread: Dolphin Nautilus damaging walls ?
    May 2013
    North East Ohio
    959
    So I was about to pull the plug on this, but then I read some reviews on Amazon that the "black" housing causes black rubber marks on the walls when it bumps into them.
    Has anyone who has one (or experience using them) had this problem ?
    I have a fiberglass pool, and I know that the walls can scuff and if this MIGHT be a issue I need to avoid this cleaner.
    Thanks in advance!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Dolphin Nautilus damaging walls ?
    Can't say, I have the M5. No black tracks or bumpers on it anywhere.
    Essential Links:
    May 2013
    North East Ohio
    959
    Quote Originally Posted by Patrick_B View Post
    yeah....I know....that is why I am second guessing
    May 2013
    North East Ohio
    959
    Hopefully someone will have some experience with this model....I think plenty on this forum own one.
    May 2013
    North East Ohio
    959
    Well I ended up buying one - and I purchased from Amazon. I know I might have a warranty issue, but at least I know I can return trouble free in the first 30 days if I get these black marks on my walls.
    Jul 2014
    Belle River, Ontario, Canada
    12
    I bought a Nautilus about one month ago. No issues with my vinyl liner. I absolutely love it, and wish I bought it sooner.
    ~15500 gal (60000 L) IG Vinyl, built 2011. Spill-over Spa. SWG - Zodiac DuoClear. Hayward Super Pump 3/4 HP. Pentair Sta Rite Max-E-Pro Booster for Spa. Hayward Sand Filter. Raypak Heater.
    May 2013
    North East Ohio
    959
    Awesome thanks for the reply looking forward to getting it in a few days
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I have a Nautilus. No problems with black marks on my in ground liner or my white steps which it regularly tries to climp up. Its a great cleaner too.
    I purchased from Amazon, but when it arrived I learned that it was actually shipped from and supplied by Epic Pool Supply.
    Even though purchased online, I have full 100 percent warranty through Epic.
    Good luck with your Nautilus, I hope it works out for you.
    couple of pics of how it goes around the pool for you.
    Divin Dave,
    May 2013
    North East Ohio
    959
    Just to close this loop...ran my new Nautilus and no black marks on the walls....but he does not climb my FG walls (addressing in a new thread)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    I saw your other thread.
    you might want to give the cleaner a couple days to get accustomed to your pool and for the scrubbers to break in.
    If you'rs was like mine, teh scrubbers were a bit flat and bumpy from teh weight of the cleaner sitting on it.. A couple days in the water and the scrubbers reshaped themselves and the cleaner just started doing a better job all around.
    Anyways, I hope you get your problem with it sorted out.
    Good Luck!
    Divin Dave,
    Jul 2014
    Outer Banks, NC
    23
    saw your other thread and replied. I have fiberglass and have not had black marks.
    12K gal, IG fiberglass, Hayward pump and sand filter, Aqua Rite 20 SWG, installed 2008, Taylor K-2006 w/magnet spinner
    May 2013
    North East Ohio
    959
    Yep, so far to good on mine, no black marks....have used it about 4 - 5 times.
