Results 1 to 16 of 16
Thread: Return valves
    Return valves
    I think i need new return eyeball valves (adjustable ball socket ones for top water movement). I have 3 and the ball socket thing inside can pop out and float away. Not sure if this is by design to swap them out. I also noticed that the closest one to the pump is the strongest. Do they make a replacement that can adjust the flow so the last one (farthest one) can be the strongest to push the debris to the skimmer?
    I see they sell the whole assembly do these simply unscrew? how do I know which size to get or are they all the same size.
    thanks!
    13000, AG, Plaster, Pentair equipment pump salt, automation, 3hp pump, 11 years old, TF-100 test kit, city water, pool cleaner vac, South Florida
    22,553
    Re: Return valves
    The eyeball fittings screw into the wall fitting. They are normally 1½" threaded fittings.
    You can get different sized eyeballs to go in the fittings, so you could put a smaller one on the strongest and larger one on the weakest to help regulate the flow.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,516
    Re: Return valves
    sunplay.com has all shapes, sizes and colors.
    http://www.sunplay.com/catalogsearch/result/?q=eyeball
    Re: Return valves
    Quote Originally Posted by Bama Rambler View Post
    Wouldn't the smaller hole make it shoot stronger because the stream is smaller like a garden hose nozzle?
    38,540
    Re: Return valves
    It would add restriction which would make more water go toward the further jets than have less restriction. Your hose analogy does not work because there is only 1 outlet in that case. You would need to have a Y at the hose bib with both hoses running and then restrict the size on one of the hoses.
    22,553
    Re: Return valves
    What the smaller stream would do is restrict the volume of water allowed through the eyeball and therefore divert more water down the line to the other larger eyeballs.
    While you might perceive more pressure out of the eyeball it's just because of the restricted opening.
    Re: Return valves
    good points! thanks guys.
    Re: Return valves
    Slit vs hole openings? any real difference?
    anything good about this?
    http://www.poolsupplyworld.com/Param...iJet-White.htm
    DFW, TX
    24,516
    Re: Return valves
    Slit shoots water out in a vertical or horizontal fan and round shoots it out in a jet. I would think the round would be better for general circulation an slit would be better for a specific application that requires more sweeping water flow. I have all round, except for a flat one on the sun shelf.
    Re: Return valves
    having a hard time getting the old ones out. Is the thread backwards? ie not nut and bolt righty tighty?
    38,540
    Re: Return valves
    Should be standard threads
    DFW, TX
    24,516
    Re: Return valves
    I use a wash rag to get a better grip.
    Re: Return valves
    Quote Originally Posted by pooldv View Post
    Could they be glued? pool is like 10 years old. I tried to turn it with some channel locks and it sort of pulled out of the wall with the pvc still attached. It did not look like it was loosening at all.
    38,540
    Re: Return valves
    Well they could be glued, but no idea why anyone would do that.
    Can you post a picture of what you are dealing with?
    You may need to hold the outside while trying to unscrew from the inside to avoid the entire thing twisting.
    Re: Return valves
    turns out they are not threaded. They just pop off.
    Re: Return valves
    Quote Originally Posted by chachdog View Post
    any idea where to buy these kind? they don't appear to be popular. should i add a threaded pipe to what is there without an eye installed to get a thread to use a threaded one or will it stick out too far?
