Results 1 to 10 of 10
Thread: PH level to make eyes sting less
    Hi All,
    I keep seeing differing opinions when I searched on this, so I thought I would post for myself and continue the debate!
    My Daughter keeps complaining that her eyes are stinging when opening them in the water.
    Do I lower the PH towards 7.2, or bring it up towards 7.8 to make eyes sting less? My PH is right on 7.5
    My TF-100 Tests last night after the swim
    FC 3.0
    PH is 7.5
    TA 90
    CH 230
    CYA very little (Did not re-test though I added some last night finally)
    Your thoughts!
    Thanks Dan
    24' Round 54" Impulse Ovation AGP, 1.5 HP 2 Spd, 150 Sq Ft. Cartridge Filter, RayPak 130K BTU NG Heater, BBB in full effect!!
    Vist TFT Test Kits --- Visit Pool School ---
    Visit the Pool Calculator
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: PH level to make eyes sting less
    With no Cya, 3 FC could contribute, but to further comment, I'd want to see the CC number. The pH of 7.5 should be perfect.
    Essential Links:
    Quote Originally Posted by Patrick_B View Post
    my CC number was 0 last night (Has occasionally been .5 since I opened, but in line with the normal testing goal guidelines)
    I did add CYA last night so maybe that will help reduce the sting.
    Even though "I" think 7.5 is great... if I wanted to adjust PH to reduce sting, would I go lower or higher than the 7.5?
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    avg. human tear is pH 7.0.... I'd wait and see what the CYA does, if it helps the sting or not. If not you could try 7.2-7.3 I wouldn't advise getting too carried away. (I suspect it's the lack of CYA)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I agree. The Cya will buffer the FC. The pH is not the problem IMO, and obviously not the CC here. I would guess it's the unbuffered chlorine in your case. Also, lots of swim time can mildly irritate anyone's eyes in perfect conditions.
    Essential Links:
    38,262
    This is a key point!
    Thanks Everyone, I will listen to the club you are beating me on the head with (That's why I come here!) and let my CYA work in before deciding to change the PH!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Did someone mention CYA?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I will also re-emphasize swimming for periods even in perfect water will irritate eyes. Especially if they are open under water, for even short amounts of time.
    Essential Links:
    May 2014
    Clarksburg, WV
    331
    My levels are CYA of30, FC right about 4-5 and pH of 7.5 and nobody in my family complain about stinging eyes.
    My fish of a 6yr old is always underwater with his eyes open. Never even get bloodshot.
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
