Thread: Hayward H250FDN Heater Error Code HS
    swirlywater's Avatar
    Feb 2015
    columbia station / OH
    63
    I have had my pool open for a few weeks now and just turned the heater on. My pool heated up to 75, then I noticed the HS error light was on. My heater is only a year old, i have a call into the pool builder but haven't heard back. Does anyone know if this is a part that commonly goes bad (so I should keep a spare on hand) or if it is a DIY fix? It looks like it should be simple enough to repair though I haven't looked into where to buy them or how much they cost.
    20x40 30k gal vinyl, Inline Tri-Chlor Chlorinator, Hayward 250K btu heater, Hayward 2HP Super Pump, Hayward DE6020 Filter,
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Re: Hayward H250FDN Heater Error Code HS
    Heater is still under warranty so don't monkey with it yourself. Call Hayward if the PB doesn't respond. Pool builder may not be a warranty tech for Hayward. They just install them.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Feb 2015
    63
    Paul, i clicked on your link so it seems you might know the answer to this. What is the effect on the heater of have the in and out lines crossed? Last year when I winterized i must have switched them and didn't look close enough this year when I opened because I didn't take them off. Since start up my pump pressure was running a little higher than last year, but I was still within a normal range so I just assumed i didn't clean the grids good enough. PB came out, uncrossed the lines so I am no longer pushing water through the heater the wrong direction and went on his way. The error code cleared and I noticed by pressure dropped about 6PSI on the filter. I have been running it this way, without the heater on, for about a month. Could I have caused myself any problems?
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    No you are OK. Just mark the lines for the next time you disconnect.
    Paul
