Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Here comes the stress!!!!!!
    Aug 2014
    East Northport, NY
    155
    I have the loop loc off and the robot is running. I used Poly 60 at closing but do have algae. I usually don't run the robot but the water is clearer then in the past and I wanted to see if it still ran which it does.
    I am having my SWG installed and wired over the weekend but between now and then should I test the water out of the gate? I have some leftover chemicals and shock so I am not sure if I should lay off doing anything until I test and post or add shock or other startup chemicals I typically used. Partially to get rid of them????
    I know when I turn on the pump I will have some leaks and my intent is to do a power vacuum to waste to bring the water level down and really get great suction and get rid allot of the **** in the pool. So I think I answered my own question. Probably best to run pump, get water to level I want it, test water and then post? Good?
    Since the SWG isn't installed I have the old cholorinator hooked up with no chemicals in it.
    Appreciate the feedback
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Here comes the stress!!!!!!
    Once you are circulating for an hour or so, the first thing you need to do is test. Don't do anything else until you have some good numbers. Do you have one of the recommended kits?
    How do you mean you'll have leaks?
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    We need testing numbers from your Taylor
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    Aug 2014
    East Northport, NY
    155
    I updated my signature to include the robot and TF-100. By leaks I mean the plumbing between the pump and other PVC areas. It is my annual Sisyphus experience! Pump is 17 years old and came with house when we bought it. That plus the filter connections etc usually lead to a leak
    TF-100 Test Kit
    Aquabot Bravo
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    OK,
    Are you able to keep the pool circulating? Just FYI, the robot isn't for this part of the process. If you have debris in the pool, rake out the bulk, but he wont help you on the Algae. You'll have to kill and filter it with the pool system.
    Essential Links:
    Aug 2014
    East Northport, NY
    155
    Pool is circulating. Slow drip from attachment point from the component that you turn to waste, filter, backwash etc. It's the type where the are two outputs that screw into the filter. I think it is a leveling issue.
    I plan to waste vac it - get the water down and test later
    TF-100 Test Kit
    Aquabot Bravo
    38,521
    If you have algae, then you need to follow the ShockLevelAndMAINTAIN Process and that is done without the SWG, so no reason to wait for that to be installed.
    Aug 2014
    East Northport, NY
    155
    In the process of SLAM and here are my numbers, thoughts?
    FC - 5
    TA - 90
    CYA - 35
    Calcium - 125
    Thanks
    TF-100 Test Kit
    Aquabot Bravo
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    You need to get FC up to shock level. It is way below. What is your CC?
    Your shock level will be between 12-16. I would go with a FCshock level of 16.
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Are you slamming? Why is your FC at 5? That is way low.
    SLAMing Your Pool
    Aug 2014
    East Northport, NY
    155
    Tested again - pool getting clearer which is awesome. Love feedback on my last test:
    FC - 22.5
    CC - 3
    TC - 25.5
    CH - 200
    TA - 140
    CYA - 27
    TF-100 Test Kit
    Aquabot Bravo
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    What was your overnight loss?
    Aug 2014
    East Northport, NY
    155
    Don't know that yet, because I didn't want to test it after I added a bunch of bleach last night, but I am not going to add anymore. Was figuring wait until tonight and test again. Also, and which could complicate things is I am having my SWG hooked up today but cant add salt until tomorrow AM, since the pool I purchased the salt from at (4.99 per) didn't have any in stock, which I can't fathom. Anyway, appreciate any feedback.
    TF-100 Test Kit
    Aquabot Bravo
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    What are you using to chlorinate the pool?
    Love TFP? Become a
    TFP Supporter!
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    You want to test it in the morning to see overnight loss. That tells us if something other than sun is destroying your chlorine.
    Aug 2014
    East Northport, NY
    155
    Will do. I assume no point in turning on the SWG until I add salt right?
    TF-100 Test Kit
    Aquabot Bravo
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Yes without salt it isn't doing anything
    Aug 2014
    East Northport, NY
    155
    Yesterday ran the pump for 4 hours and conditions were overcast but here are my readings:
    FC - 20.5
    CC - 1.5
    CH - 175
    TA - 110
    CYA - 30
    Pool is still cloudy by undoubtedly better then when we started. Appreciate any input
    TF-100 Test Kit
    Aquabot Bravo
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
  20. Back To Top    #20
    Aug 2014
    East Northport, NY
    155
    This was yesterday AM. So 2% on the FC. Do you think the pool will continue to get clear - a little foggy right now
    FC - 22.5
    CC - 3
    TC - 25.5
    CH - 200
    TA - 140
    CYA - 27
    TF-100 Test Kit
    Aquabot Bravo
